02-22-2017, 11:00 AM | #1 |
Rep 2,808
So I came to swap my winters for my lovely 19" summer wheels the other day. Got all 19 nuts off apart from the very last one which happened to be the secure bolt on my rear wheel. Could I get the bugger off? No. So called BMW Assist, he couldn't do it either and suggested the security key was slightly damaged or worn and I should call my local dealer and get another even though it has worked on the other 3 secure nuts. I know what secure key number it is so can order another if needed.
So called dealer. They have told me I need to book a service and be charged for the dealer to assess if the key or the wheel bolt is faulty. Seems excessive as it would probably take someone 2 mins to get a wheel gun on it. Then they said it would take about 4 weeks for a new key to arrive! As the car is only 10 months is it excessive that I have to pay to found what is wrong with the nut or key? Tempted to take it to my local tyre fitter and get them to get it off. What do you guys think?
Current: G26 i4 M Sport Pro, Tech Pk, Sunroof
Previous: 2016 440i MPPSK, 2014 330d Saloon F30, 2013 Audi S4 Avant, 2011 Mercedes C350 |
02-22-2017, 01:47 PM | #2 |
Rep 834
Is the security key slipping/spinning on the bolt?
If not then the bolt is seized for some reason. Possibly corrosion.
BMW X1 sDrive20i ///M Sport MHT
02-22-2017, 03:13 PM | #4 |
Rep 298
My son had a brand new Corsa, which he had a puncture in. I went to assist him, to discover the locking wheel nut would not budge. Some twat had done it up with an air gun.....Took it to Vauxhall and they decided to charge him for a new set of wheel nuts and the time to take them off, when it was those twats who had serviced it......That was an interesting conversation.....Ended up taliking to Vauxhall head office, who told the dealer to sort it at their cost....Who put the winters on?
02-22-2017, 03:22 PM | #5 |
Rep 2,808
The security key just slips off the bolt. Works fine on the other three bolts. Neither the key or bolt look damaged.
A local tyre fitter who I have used for years put the winters on when they fitted my TPMS valves. I will stop by tomorrow on the way home from work and see if they can help. Screw BMW charging me. I asked the parts department for my key number. They got a master set out and tried them all until it fitted.
02-22-2017, 03:30 PM | #6 | |
Rep 298
02-22-2017, 03:54 PM | #7 |
Rep 311
Common problem unfortunately. The locking keys are shite!! You could try putting the key on the bolt and tapping it with a mallet before trying to get it off. And use a long bar for added leverage.
02-22-2017, 03:55 PM | #8 |
Rep 2,808
Yeah I tried that as did the guy from BMW Assist. Wrench just kept slipping off with key attached. Feels like the wheel nut is either over tightened or slightly worn.
02-22-2017, 03:56 PM | #9 |
Rep 834
Just tried my Irwin Bolt Grips. The largest that I have is 19mm (3/4") but it is too small. You might be able to hammer on a cheap bi-hex 22m socket but there is real danger of damaging the recess in the wheel where the security bolt sits.
I would be tempted to sacrifice the key and bolt set by packing some steel epoxy putty in and letting it set overnight with the key in place. It might provide enough temporary grip to crack the bolt free. Depends how much the stealers will charge to free off the bolt with their master key and supply you with a replacement key. Many years ago some scrotes broke into several cars on our street and stole the locking wheel bolt keys, including the one from our Fiesta. The supplying Ford dealer sold me a replacement key and bolt set and loaned me their master key set for free whilst I changed the bolts over outside their workshop.
02-22-2017, 03:58 PM | #10 |
Rep 2,808
Think I will take it to my tyre fitter first and see what they can do. If they can't will have to pay the buggers at BMW to sort it.
02-22-2017, 04:07 PM | #11 |
Rep 3,560
Surely they will take it off for free? Then just order a new set of bolts with key for about £35 quid I think.
or £20 https://www.amazon.co.uk/BMW-36-13-7.../dp/B004V4ILA2 |
gr4z1135.00 |
02-22-2017, 04:09 PM | #12 |
Rep 2,808
BMW have already said they won't do anything for free. I apparently need to book it in as a service for them to 'investigate' the issue!
02-22-2017, 04:11 PM | #13 |
Rep 15,858
Sounds to me as if the bolts have been overtightened, or the key not correctly engaged before use. The bolts only require torqueing to 140Nm +/- 10Nm, no reason to damage the locking key.
If anyone requires a long breaker bar, the bolts are definitely over tight. |
ronime343.50 |
02-22-2017, 04:14 PM | #14 |
Rep 2,808
Thanks guys. I will order the ones mentioned above from Amazon if I can the old ones off!
Assume those from Amazon that mention they are for the F30 would be the same for F36.
02-22-2017, 04:14 PM | #15 | |
Rep 3,560
One of the cars I bought had a wheel bolt missing!!! When they order a new set of bolts they found the reason it was missing because at some point it had been crossed and needed a new hub! |
02-22-2017, 04:15 PM | #16 | |
Rep 15,858
There is another side to it, if the bolt is overtight. If it is the key, the dealer's master key may get damaged trying to undo the bolt. I'm aware of this happening to one of my neighbours, with a BMW dealer. |
02-22-2017, 04:16 PM | #17 | ||
Rep 2,808
02-22-2017, 04:38 PM | #18 |
Rep 1,060
There is a sequence of unbolting wheels with the Mcguard BMW locking bolts. When removing a wheel you should loosen the locking bolt first before the standard bolts. On refit the locking bolt is torqued up last. I have had no problems following this procedure torquing up to 140 Nm.
G15, 840i M Sport
Lorcan3609.00 |
02-22-2017, 04:58 PM | #19 | |
Rep 161
Solution: took car to kwik fit, lad put the key on, gave it some hard twacks with a hammer with key on the nut and then cracked it off with the torque wrench. |
02-22-2017, 05:48 PM | #20 |
Rep 834
Irwin do a specific set of lug nut extractors but they ain't cheap:
https://www.machinemart.co.uk/p/irwi...bolt-grip-set/
02-22-2017, 05:54 PM | #21 | |
Rep 834
I'm going to hazard a guess that there are circle, square and triangle stickers in a variety of colours.
02-22-2017, 07:11 PM | #22 | ||
Rep 1,894
