02-18-2017, 06:42 PM | #1 |
Rep 1,455
Front pads
I decided today to fit my nightbreaker bulbs as the weather was pretty gppd today.
After struggling to see into the hole in the wheelarch I decided to take the wheels off for better access. Firstly the wheels didnt want to come off, after a bit of kicking they let go but seems clear they haven't been removed recently despite what the service history might suggest. Put some copper slip on the wheels so hopefully wont stick again However I looked at the front pads and they seemed pretty low, perhaps 4mm. No warning on dash and idrive says 10000 miles left. I think Ill be happier changing them soon, but how low do they need to wear before a warning gets triggered ? Thinking I'll do a oil / oil filter front pad change shortly even though idrive says not due - not sure I trust all this condition based servicing |
02-19-2017, 04:52 AM | #2 |
Rep 32,881
I think the sensor triggers at around 3mm, which is really low tbh.
I changed my front pads and discs yesterday, and although the wear sensor hadn't even started to wear, I couldn't even remove the spring clip from the pads as they were so close together! |
02-19-2017, 04:58 AM | #3 |
Rep 810
Mine were like that, the idrive tries to estimate it but once the sensor trips it'll suddenly go down to amber and a couple of thousand left.
@teaston how many miles have you done you've not had the car long? |
02-19-2017, 05:06 AM | #4 |
Rep 139
Don't ever trust the car.
This is the result -
Currently - F98 X4M Competition / E82 118d m sport coupe
Previously - F06 640d Gran Coupe, F30 320d, e46 330ci, 120d M Sport E87 - 135i Backbox, E46 330i Clubsport, Before that - E36 Coupe 328i |
02-19-2017, 06:36 AM | #5 |
Rep 32,881
02-19-2017, 10:04 AM | #8 |
Rep 707
02-19-2017, 10:06 AM | #9 |
Rep 379
02-19-2017, 10:19 AM | #10 | |
Rep 32,881
image upload with preview |
ar68149.00 |
02-19-2017, 10:26 AM | #11 | |
Rep 379
02-19-2017, 10:41 AM | #13 |
Rep 379
02-19-2017, 10:50 AM | #14 | |
Rep 32,881
Gone with Pagid pads, currently £33.30 delivered using promo code VOUCHERBOX13 here: http://www.carparts4less.co.uk/cp4l/...d2bc85c&000036 |
ar68149.00 |
02-19-2017, 11:24 AM | #15 | |
Rep 155
Why I ask is the original pads on my car were very noisy & squeaked at low speeds (common issue as seen on this forum). I returned the car to BWM & in the end they fitted new pads all round. They worked without issue but now the squeak is back & I have only covered 1000 miles on the new pads + the amount of dust that created is not good with black wheels. |
02-19-2017, 11:30 AM | #16 | ||
Rep 32,881
I think the main cause of the squealing is the aluminium hats on the M Sport discs not damping vibrations like one piece iron discs do. My new discs are one piece so I'll find out soon if they squeal or not. |
02-19-2017, 12:02 PM | #17 | |||
Rep 2,152
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
02-19-2017, 12:19 PM | #18 |
Rep 1,455
Just looking at genuine BMW pads which seem to be over a hundred quid
Other makes available from ECP / carparts4less less than half the price I always used Pagid on my old E39 and had no issues Is there any reason NOT to use BMW pads given the price ? And Textar and Pagid seem a similar price, anyone have a view on which is better ? |
02-19-2017, 01:22 PM | #19 | |
Rep 1,705
"Vehicles without M-Sport package" for those pads. I have blue M-Sport brakes so put my reg. no. into that site. It came up with a load of brake pads but all still said "Vehicles without M-Sport package". Don't really get it. |
02-19-2017, 01:58 PM | #20 |
Rep 7,484
Mine were down to 4mm and were yet to trigger the sensor. The I drive started to report 2000 miles but braking was so dangerous - it was like braking in severe wet conditions so I had them changed. Go by a visual inspection and what you feel comfortable with. No doubt there is someone out there with 3mm as they think there is life in the pad but it is not worth the risk to self or others.
teaston10994.50 |
02-19-2017, 02:19 PM | #21 | ||||
Rep 32,881
Smee505.00 |
02-19-2017, 02:23 PM | #22 | ||
Rep 32,881
If you want to see all the pads that will fit then have a look here: http://m.onlinecarparts.co.uk/spares...rd=34116859066 |
