E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Warning light fixed - 335d remap gone :(
      04-16-2008, 04:44 PM   #1
335DJim
335DJim's Avatar
Drives: 335D Coupe
Update -
Had the rouge 'Brake Light Failure' fixed at dealers today - they changed the convenience unit that runs the cars lighting system - this meant a reprogram of the car to synch it up. Soon as I drove away I realised this had blanked my 'ChippedUK' remap..
Will have to call them tomorrow to get it booked in for a re-flash.. forgot how mellow they are stock, can really feel the difference.
      04-17-2008, 03:05 AM   #2
Evil Diesel
Evil Diesel's Avatar
Drives: E92 335d M Sport
That it properly irritating.
I may need an iDrive update so this is likely to kill the map in mine as well.
      04-17-2008, 03:12 AM   #3
nagge
Swedish user
nagge's Avatar
Sweden
Drives: 06' E90 330dA
Bah, I guess this means having my radio replaced and reprogrammed will overwrite my remap as well
Well It's a nice 900km roundtrip to Norway if anything
E90 330dA | SG | Remapped | Blacklines | Matte black kidney grill | M3 Steering wheel | Ümnitza Predator ICE LED Angel eyes | 18" M5 reps | ESS Tuning
      04-17-2008, 05:27 AM   #4
red-max
red-max's Avatar
England
42
Drives: 520d M Sport
I'm fairly convinced my re-map was over-written when my car had new keys and locks replaced. Although they had to "code" the "control unit" to match the new key fobs, I wasn't expecting new software, but it looks like I got it anyway. I don't have iDrive, but I have noticed that the font on the information panel (between speedo and tacho) has changed.
Anyone know why the ECU would be re-programmed? Does the dealer just do a complete software update and this includes the ECU, or is this a cunning plot by BMW to discourage customers from re-mapping their cars?
2018 G30 520d M Sport with M Sport Plus - Mediterranean Blue
Previously: 2015 F32 430d M Sport, 2012 F10 520d M Sport, 2009 E92 320d M Sport, 2006 E92 335d, 2004 E60 530d, 2000 E39 525d, 1997 E39 523i
      04-17-2008, 07:20 AM   #5
mjh93sa
mjh93sa's Avatar
147
Drives: 530d
The process of coding the car it seems was a bit of a new idea for the E9x and as a result there are more than a few buglets.
From what I have been told by the service guys during an open day at the dealer thay cannot program a single module, only the whole car! This takes forever and a day. The process is further complicated by the fact that if the programmer crashes, or power is lost then it will most probably fry the module that it was programming at the time. In this case they have to replace the module and start again.
hence a radio change can take all day to do... if you're lucky.
Gone: Fiesta - Focus - E46 320dSE - E91 330dMSport - E82 135iMSport - R55 JCW Clubman - M135i
Now: 530d
      04-17-2008, 11:59 AM   #6
CD
gone ... but i will be back !
CD's Avatar
England
62
Drives: 335D Coupe
would they reprogramme the ecu on a standard service ? i carnt imagine they would, only if there was a problem !
E92 335D / QUAIFE LSD / EIBACH / DIMISA / REMAP / 19" HAMANN EDITION RACE REPS
... USUALLY WITH A HEALTHY SPLATTERING OF GOOD OLD YORKSHIRE MUD ...
      04-17-2008, 12:05 PM   #7
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
949
Drives: 997.2 GT3
You guys want to be aware, bmw flash a different set up on there. I have found this out already. Your original map which is saved by the tuner can not be re-installed and a new map needs to be written.
Now when mine got wiped for the first time, i thought it felt slower, but with a bit of a razz it still felt quick. But i had driven a mini cooper for two days so a stock 335d would feel quick. Went back to the Tuner just incase and the car felt ballistic after the re-map really confirming it was ''knocked to stock'' as it were.
997.2 GT3
      04-17-2008, 04:46 PM   #8
PhilR
PhilR's Avatar
Drives: E93 330d M Sport Auto
Carlos,
I asked you last week if you had lost your map after the service as I thought this may have been the case..........
You say that a new map must be written by the tuner. I can understand this else the new info on the Dealer map will be lost too if the first remap were flshed again.
I do believe that once the tuner has gained access to your ECU for the first time (they removed mine from the car to "crack it") it's a case of plugging a lead into the diagnostic port of the car, downloading the revised dealer map, modify and reflash the ECU.
Is this the case with your 335d?
PhilR
      04-17-2008, 04:49 PM   #9
dxb335d
dxb335d's Avatar
England
949
Drives: 997.2 GT3
Originally Posted by PhilR View Post
Carlos,
PhilR
Yes and modify is the key word. The map will not be the same as previously installed. Every map has its sliigght differences
they removed my ecu first time. Bmw still flash over it and the original tuner map can not go back on.
They need to tweak the file!
997.2 GT3
      04-18-2008, 02:08 AM   #10
deejaygee
Drives: 320d M Sport
Spider Tuning Box seems better everyday. Took mine out last night as it's in for the hub & caliper replacement today.
Will pop it back in later...........
      04-18-2008, 02:40 AM   #11
PhilR
PhilR's Avatar
I agree it's nice to able to pull it on and off (your spider tuning box) when visiting the dealer. The tuning boxes are cruder but do work very well.
Unfortunately I have had issues the diesel tuning boxes in the past. One worked fine for 18 months on my Golf GTTDi, another worked well for 12 months Saab 9-3 TiD then pow.....car went into limp mode, clogged injectors, 3 trips to the dealer and it was only set to about half way. Had to remove it completely - still have it at home somewhere
Not sure if this is an isolated case?
Hene me deciding on a re-map instead for the 330d - Sorry a MODIFICATION (Carlos's benefit)
Has anyone else had issues with Tuning Boxes / Spider Boxes?
PhilR
      04-18-2008, 02:55 AM   #12
Cafe.Racer
Cafe.Racer's Avatar
Drives: 320d Touring
AFAIK all tuning boxes all work by increasing the amount of fueld going into the engine.
There's two ways to do this, up the fuel line pressure (so more fuel squirts out for each injector pulse) or increase the injector pulse width (how long it squirts for).
There can be other considerations, like throttle angle.
The tuning boxes that you had on your Vauxhall and SAAB - what type were they?
Phil
      04-18-2008, 03:35 AM   #13
deejaygee
I think Spider box works differently to most to be honest, the box contains 25 Engine Maps - and adaptive scan functions which switches to how you are driving at the time.
The power delivery is not crude like you would find if the box simply increased fuel pressure.
      04-18-2008, 04:49 AM   #14
PhilR
PhilR's Avatar
Deejaygee.
I should explain what I meant by crude. I'm not suggesting that the power delivery is anything less than smooth. I know you get good results from tuning boxes.
I have done a fair bit of reasearch on Tuning Boxes etc over the past few Years and what I mean by crude is that a tuning box can only alter the fuel by either upping the pressure or increasing pulse width (duration of each squirt) this does have an indirect effect on boost too - as the engine temp and pressure rises and produces hotter gases that spool the turbo more.
Both tuning boxes I have used made the car smoke - by overfueling the engine resulting in some it cannot burn (not enough O2) under hard acceleration. Emissions are effected too.
A remap however can adjust the fuel pressure in the rail, injector timings, pulse width, air intake, turbo pressure, etc etc and works in harmony with the cars ECU -so it effectively re programmes the car to deliver better performance with no smoking at all.
PhilR
      04-18-2008, 04:51 AM   #15
deejaygee
Well I can honeslty say that I have no more smoking at all.
      04-18-2008, 04:58 AM   #16
PhilR
PhilR's Avatar
The tuning boxes
A DragonPerformance analogue tuning box on my VW GTTDi (150) and this worked very very well - smoked a bit under hard acceleration but worth the £100 I paid for it (4 Years ago) - sold it on Ebay for £70 after 18 months
A CR Digital Tuning Box (£250 - cannot reacll company I bought from) on my 9-3 TiD (150) - worked fine for a Year and then had to take it off completely. Clogged the CR, emissions sensor kept tripping. Was a total nightmare.
PhilR
      04-18-2008, 05:32 AM   #17
gIzzE
gIzzE's Avatar
363
Drives: F11 + 911 C4
I think the Sabb one was from tunit??
I had 3 faulty ones for my E46 and then two faulty ones for my A3 and gave up with tuning boxes.
Also the tunit boxes threw the obc mpg reading right out, said it was up from 32mpg to 50+ but still doing the same miles per tank.
The spider box gives true mpg readings, but that might be that the E90 measures them differently?
      04-18-2008, 06:27 AM   #18
PhilR
PhilR's Avatar
Saab Tuning Box wasn't from Tunit I know about these - it was some outfit in Scotland trading on Ebay just cannot remember their name.
I know what you mean about the MPG - the analogue unit on the VW was telling the OBC I was getting 54MPG - when I was actually getting 43MPG
The tuning box on the Saab was giving fairly accurate MPG readings to the OBC.
PhilR
      04-22-2008, 10:50 AM   #19
nagge
Swedish user
nagge's Avatar
Sweden
Bah, new radio, remap overwritten
80-120 (3rd) 3,6s before, and 4,3 after
      04-23-2008, 06:12 PM   #20
335DJim
335DJim's Avatar
Drives: 335D Coupe
My remap has been re-instated (FOC) by ChippedUK - thanks guys!
e90post
