M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      01-02-2017, 09:25 AM   #1
Lowflight
Lowflight's Avatar
Drives: 2012 E93 M3
Is Kendall Oil ok for the F10 M5?
That is what my BMW mechanic uses and wanted to make sure before he does my first oil change on my 2013
      01-02-2017, 10:13 AM   #2
ARC550
Drives: M3, X5, 720s, X5, 750xi
Liqui molly 5w30 and done.
      01-10-2017, 09:06 PM   #3
ur20v
Drives: F10 M5
Olive oil - light.. done.
If the specs match BMW's specs and or on the approved list then you should be good to go. Note BMW can't hold the oil against you if it matches their specs same with spare/service parts - they don't have to be OEM.
Ask which oil is best or to use is going to make for another long and opinionated thread not base in engineering or science!
      01-11-2017, 10:40 AM   #4
Lowflight
Lowflight's Avatar
Drives: 2012 E93 M3
Thanks. That is all I care about. He has Kendall at his shop and as long as the weight is correct I should be good to go given my car is CPO, I don't want to give those arrogant pricks at my dealership a reason to void me.
      01-12-2017, 08:42 AM   #5
stealth.pilot
Knight Commander
stealth.pilot's Avatar
Drives: 2014 911 Turbo S
I would use Castrol 0W-30. It has a huge advantage which is that it reaches operating temperature sooner so within a couple of minutes you can unleash the engine. Mobil 1 is fine.
quick search online suggests Kendall doesn't make 0W-30
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      01-13-2017, 03:16 AM   #6
ur20v
Drives: F10 M5
Isn't the oil spec 5W-30? Its is here in Oz...
      01-13-2017, 04:35 PM   #7
E90Fleet
South Africa
1312
0W for countries where the temperature dips below -20C
BMW if you are reading, I need a job, Please.
      01-22-2017, 05:05 PM   #8
GMWNashville
Drives: 19 G05, 16 F80, 10 E70x5D
If your mechanic uses Kendall oil you probably shouldn't continue to use them as they use kendall oil because its cheap...not because its good.
      03-12-2017, 03:35 PM   #9
123Britt
Drives: 15 M235i AT
Bring the oil to him
Pennzoil EURO 5W-40
Their are others -- but do some research -- this is a good oil for your car.
That is if you plan to have a long term relationship with your M5. If you plan to sell before 100k -- then just put in whatever.
      03-20-2017, 11:01 AM   #10
GMWNashville
We use Liqui Moly in my shop
      10-05-2017, 06:56 AM   #11
Lowflight
Lowflight's Avatar
Drives: 2012 E93 M3
I just got him to stock up on BMW M oil
m5post
