BMW 5-Series (G30) Forum 2017+ BMW 5 Series (G30) General Discussions Re-ordered After Incorrect Data Online - Better Result
      12-14-2016, 03:06 AM   #1
jedpause
jedpause's Avatar
Drives: G20 330e M Sport '21
Well, after ordering at end November, dealer advised some issues (combined items not same as initial online configuration), but plus side is prices went down so could add toys. Company car so trying get best bang for buck and avoid CO2 based tax)
520D M Sport Auto
Bluestone Metallic
Black Leather - Blue Stitching
Enhanced Bluetooth - w/wireless charging
Folding side mirrors w/memory
Full electric seats w/memory
Variable Damping Control
High Beam Assistant
Sun Protection Glass
Rear View Camera
Online Entertainment
Advanced Speaker System 676
12v Socket extra x 2
WiFi Hotspot
Delete M Badges on sides
Delete M Sport Suspension
Delete Model Designation
Delivery Date 20th March, just under £44k
Sunset Orange G20 330e xDrive M Sport Pro - Tech/Pro Pack, Park Assist Plus
Bluestone G30 M Sport - Gone to Stud
Alpine White F10 M Sport - Gone to Stud
      12-14-2016, 04:40 AM   #2
Bandiano
Bandiano's Avatar
Drives: F11 530d Msport Touring
What changed ?
BMW F11 535d Msport touring
Jaguar XKR100 Convertible
Mini Electric
      12-14-2016, 01:18 PM   #3
jedpause
jedpause's Avatar
Originally Posted by Bandiano View Post
What changed ?
Wi-Fi can't be ordered on it's own (needs Enhanced Bluetooth w/Wireless Charging, so added that)
And although it is in my list, I couldn't delete M Sport suspension if I have VDC...
..weird but a pity, tried a couple with Sport Suspension before and quite unforgiving over lumps and bumps
The online configuration is all fine now... it was a Beta or something when I first tried or, didn't link all the options properly
      12-14-2016, 01:58 PM   #4
remmib
remmib's Avatar
Norway
1566
Drives: 2013 F10 520d M-Sport
Deleting the M sport suspension is only possible if you haven't opted for another suspension than M sport. Since you've got the VDC, there's no M sport suspension to delete.
      01-06-2017, 04:37 AM   #5
jedpause
jedpause's Avatar
Yes, they have changed the config site since I ordered (UK), you now have to ADD M Sport suspension if you want it... it is not a default like it used to be on M Sport models.... (and you can have both VDC and M Sport Suspension if you want according to BMW)
Also good is you have to ADD smokers package, not default anymore
20th March, roll on
      01-06-2017, 05:14 AM   #6
E90Fleet
South Africa
1311
Technically VDC deletes M Sport Suspension
BMW if you are reading, I need a job, Please.
      01-06-2017, 05:43 AM   #7
AP
AP's Avatar
2762
Drives: G30 M550
Is VDC any different on a msport compared to a SE? ie ride height , is that the same regardless whether it's SE or msport?
      01-06-2017, 06:02 AM   #8
remmib
remmib's Avatar
Norway
1566
Right, I know. Poorly worded on my part.
As I understand it, no. Only m-sport suspension will lower the car.
      01-06-2017, 07:30 AM   #9
E90Fleet
South Africa
1311
Correct
You can actually see it on the German Configurator
Click "Details" under M Sport Pack and then change between the Suspensions available. It will drop the car height only with the M Sport suspension
Not quite so easy to see below
But if you save both images and then switch between the 2 you will see it go from lower to higher suspension.
Lower is M Sport suspension
      01-06-2017, 10:24 AM   #10
remmib
remmib's Avatar
Norway
1566
Correct
Cool, haven't thought about using the configurator to check the ride height.
So I played around a bit to see if the new combo, xDrive and M-sport suspension also get a drop, and it did.
But then I checked to see if 530 and 540 got different sized M-sport brakes, and the configurator shows the same size brakes.
