M2 Technical Topics > Cosmetic Modifications > Shark fin
      11-12-2016, 02:29 PM   #1
DocWardM2
DocWardM2's Avatar
Drives: 16 M2 MG 6MT
Shark fin
Does anyone know if the shark fin is attached via a bolt or simply adhesive?
      11-13-2016, 01:39 AM   #2
ORIGIN M.
Drives: ///M
Adhesive, then the actual antenna is bolted to the roof.
So If you wanted a Black one or wanted to wrap it or the roof, you'd have to get busy with the dental floss.
BAN_M2C4178.00
      11-13-2016, 07:16 AM   #3
DocWardM2
DocWardM2's Avatar
That's what I figured. Thanks for the reply.
      11-19-2016, 04:28 PM   #4
DocWardM2
DocWardM2's Avatar
Hey guys. I figured I would give you guys an update.
Dental floss did not work. The adhesive that binds the shark fun to the roof is very tough; not the usual double sided tape. The dental floss kept breaking and so did fishing line. I ended up taping around the antenna's edge and the roof and used a #11 blade to carefully cut through the rubber adhesive.
Also 3m adhesive remover did not work well on the shark fin to dissolve the adhesive.
      12-04-2016, 01:28 AM   #5
rouxeny
Living the aloha
rouxeny's Avatar
Drives: 2017 LBB M2
#11 blade FTW!!!
      12-05-2016, 10:32 AM   #6
Rock Sweden
Rock Sweden's Avatar
Drives: 2016 M2
update?
      12-06-2016, 11:52 AM   #7
banff
Enthusiast
banff's Avatar
152
for future reference, a steamer and fishing line works fine.
m2
