White stuff on metal parts in engine bay and undercarriage? |
10-16-2016, 01:53 AM | #1 |
Rep 101
So, the last time my car was on a lift, I noticed the metal parts exposed in the undercarriage area are completely covered in what looks like aluminum oxidation or salt. I also see it in the engine bay, as well (see below).
The car is 7 months old and has never been out of SoCal since it arrived in the country. A mechanic showed me another BMW in the shop that was at least several years old that had almost none of it. Any idea what's going on here and what to do about it? |
10-17-2016, 11:04 AM | #2 |
Rep 556
I had a similar problem with my RX-7, almost all the aluminum in the engine compartment had a light layer of oxidation. It turned out that there was a microscopic coolant leak that let out coolant vapor (not liquid) when the engine was very hot, for example when shutting down after a track session. The only clue was a very slight smell of coolant if you put your nose right down in the engine compartment. After several years I eventually replaced a coolant sensor buried under the intake manifold and the problem went away.
10-17-2016, 11:15 AM | #3 |
Rep 5,577
Yeah but wouldn't the coolant leave deposit on all the black plastic ? Was there the white deposit on plastic also ?
Is the car near salt water ocean ? Last edited by overcoil; 10-17-2016 at 11:23 AM.. |
10-17-2016, 01:21 PM | #4 |
Rep 101
Interesting theory (re: coolant), but yeah you would think it would also be deposited on non-aluminum parts, no?
Well, I guess it depends on how close is close. I live 15 miles inland from the coastline, but have made a few trips over the past 7 months to the beach (totaling maybe 5 or 6 hours parked close to the shoreline). |
10-17-2016, 11:27 PM | #6 |
Rep 101
Shouldn't it be protected, though? Like I said, a tech showed me an older BMW that had next to nothing, even though the owner lives in the same region. If everyone's aluminum parts look like this in SoCal, then that's one thing, but if not, then I'm confused about the discrepancy, is all.
10-18-2016, 11:24 AM | #7 |
Rep 556
Salt oxidation? He lives in Los Angles, the closest the car comes to salt is when he drives through Rubio's for fish tacos.
On my RX-7 the only effect of the coolant vapor was oxidizing the aluminum. There was no or minimal deposits on anything else, then again it's a track car and the engine is meticulously cleaned after every race weekend. |
10-18-2016, 11:30 AM | #8 | |
Rep 101
It's helpful to know the vapor only affected the aluminum parts. I think I'll stop by the dealer and bring up the topic to see if they can find a similar leak or else come up with another plausible explanation. |
10-18-2016, 03:22 PM | #10 | |
Rep 957
Salt is not only found in the oceans. This could be from any myriad of sources. Could be an industrial pollutant along his drive, could even be in the soap he or someone uses to wash the car. Your coolant vaporizing could have oxidized the metal or might have been acting as a bridge for electrolysis. More likely electrolysis if the symptoms would come on quick. |
10-18-2016, 03:23 PM | #11 |
Rep 957
10-18-2016, 03:24 PM | #12 | |
Rep 957
10-18-2016, 07:32 PM | #13 | |
Rep 101
http://strongarmbrand.com/SitePages/...eStrongArm.jpg |
10-19-2016, 09:13 PM | #14 |
Rep 129
Drives: 2016 MW M235xi
For what it's worth, I live literally 5 seconds from the Chesapeake bay and only have a fraction of the oxidation you have. Granted, the bay is only about 15 ppt salt (average ocean is about 35 ppt) but still its very salty air. I did also wonder if my oxidation was normal.
martopoulos54.50 |
10-24-2016, 05:36 PM | #15 |
Rep 101
I took the car into the dealer today. They checked for leaks, etc. and found none. They sent pictures to BMW NA, who replied saying that the level of oxidation is normal even for the age of the car. I still don't understand how it can look like that after 7 months when much older cars in the same area have even less oxidation. Nothing I can do about it at this point, though.
10-26-2016, 12:30 PM | #16 |
Rep 556
If this is the problem, I'm not surprised the dealer didn't find anything, my RX-7 symptoms were:
1. Passed a visual inspection, no signs of a leak - The stuff was vaporizing as it escaped from an almost microscopic crack in a coolant sensor hidden from view under the intake manifold. 2. Passed a coolant dye test using a UV lamp, again there was no visible seepage. 3. Passed a leak down test. - The leak was very slow and only occurred when the engine was very hot, i.e. I never detected any appreciable loss of coolant, although the coolant was replaced every year. The only sign that there was a leak was the corrosion and the very faint smell of antifreeze after a track session when I pulled into the pits and raised the hood. The smell would go away about a minute or so after raising the hood. To check for a similar situation I would suggest you drive your car for at least an hour and get it nice and hot, pull into a garage (to keep out of any breeze) and keep the hood down for about 10 minutes (to allow the vapor to accumulate). Make sure the radiator fans do not come on! Then open the hood and sniff around the engine compartment for a slight antifreeze smell. |
10-26-2016, 12:37 PM | #17 | |
Rep 101
10-30-2016, 02:09 PM | #19 |
Rep 101
11-01-2016, 11:33 PM | #21 |
Rep 101
Sort of. I've been going to the self-service, manual car washes that are so common on the west coast. It should just be high-pressure soap and water-- no acid wash or similar, if the description is to be believed.
11-04-2016, 10:44 AM | #22 | |
Rep 957
Same issue with the guys coolant, Japanese cars contain phosphate in the coolant, euro cars do not, unlikely of you had a coolant vapor leak that would oxidize the aluminum. Plus rx7, rotary, leaks and burns everything then stops running at 50k after burning 100k of gas. At high pH, the 'passive' aluminum surface dissolves as Na2Al(OH)4 (sodium aluminate). This reveals 'active' metal underneath, which reacts with the phosphates in the water to form aluminum phosphate. Sodium aluminate reacts with sodium phosphate to form sodium aluminum phosphate. Sodium aluminum phosphates precipitate out of the water, and deposit onto the sites along the surface of the aluminum leaving these powdery spots. |
