XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 Photos / Videos / Media
      10-08-2016, 11:55 AM   #1
D Unit
Drives: 2013 x1 s28i
***Official Wheel Thread***
Let's get an official wheel thread with the following format. Let's try to keep the post complete and accurate.
username -
wheels -
size and offset -
spacers -
tires (size and brand) -
suspension -
clearance - does it rub (front back)? rolled fenders?
      10-08-2016, 12:00 PM   #2
D Unit
username - tristanpaglia
wheels - Niche Misano
size and offset - 20x9 et 35 and 20x10 et 40
spacers - none
tires (size and brand) - Bridgestone re760 sport 245/35R20, 275/30/R20
suspension - KW V3 Coilovers
clearance - Initial slight rubbing front and back.
[/QUOTE]
username - Mr_Jack
wheels - Velgen
size and offset - 19x9 et35 and 19x10.5 et45
spacers - 18mm front, 12mm rear
tires (size and brand) - 255/35/19, 295/30/19
suspension - H&R Sport/Bilstein B6 shocks
clearance - Rubs up front backing out of an incline on the inner fender a tad, rear used to rub on stock shocks
username - GRANTLDN
wheels - x5 OEM wheels
size and offset - 19x9, 19x?
spacers - 15mm spacers front and rear
tires (size and brand) - Pirelli P Zero 225/40/19, 255/35/19
suspension - BC coilovers
clearance - 2 to 3 mm clearance
username - AWF87M2
wheels - Style 351
size and offset - 18x?, 18x?
spacers - none
tires (size and brand) - 245/40/19, 275/35/19
clearance - ?
username - BeemerX1
wheels - Style 405m
size and offset - 20x8 et30, 20x8 et30
spacers - none
tires (size and brand) - 225/35/20 Michelin Pilot Super Sport non runflats
suspension - Bistein B12 kit
clearance - ?
username - Booster
wheels - ?
size and offset - 18x8.5 et29, 18x9.5 et23
spacers - 12mm spacers front, none rear
tires (size and brand) - 245/40/18, 265/40/18
suspension - H&R Sports
clearance - no rubbing
username - Activ3
wheels - Rays
size and offset - 19x8.5 et24 front 19x9.5 et36 rear.
spacers - 20mm front, 12mm rear
tires (size and brand) - 225/40/19 front and 255/35/19
clearance - does rub the rear sometimes.
username - Mr_Jack
wheels - Apex
size and offset - 17x? et?
spacers - none
tires (size and brand) - 275/40/17
suspension - ?
clearance - ?
username - wantm135i
wheels - Style 225m
size and offset - 19x9 et35 square
spacers - 15mm front
tires (size and brand) - 255/35/19 squared
suspension - KW Coilovers v3 with rear KMAC camber kit
clearance - "better handling its a night and day difference."
username - Mr_Jack
wheels - Apex Arc 8
size and offset - 19x8.5 ET25, 19x9.5 ET22
spacers - 5mm front
tires (size and brand) - 225/40/19 Hankook V12 EVo2, 255/35/19 Hankook V12 EVO2
suspension - H&R springs
clearance - ?
      10-09-2016, 10:52 PM   #3
Mr_Jack
Drives: X1 35i M Sport
The white one on Velgens is mine.
username - ray340i's friend
wheels - Velgen
size and offset - 19x9 et17 and 19x10.5 et33
spacers - 18mm up front 12mm out back making it those specs
tires (size and brand) - 255/35/19 295/30/19
suspension - H&R Sports/Bilstien B6 shocks
'15 E84 X1 35i M Sport
MPI DME Flash - K&N drop in - MPI Chargepipe - Oil T-stat valve - ETS 5" I/C - N54tuning 3.5" downpipe - catless mid section - Dinan 135i rear exhaust - Apex ARC8 18x9/10(255/295 tires) - H&R Sports - Bilstein B6's - F3x M Performance brakes
'02 E39 530i 624whp/558ft-lbs @23psi
D Unit90.50
      10-10-2016, 08:08 PM   #4
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
Good job man! This will be very useful for people wanting wheel upgrades.
My rims are Niche Misano btw.
      10-10-2016, 10:29 PM   #5
D Unit
wheels - Velgen
What about the specs of your car when you had the Arc 8s?
D Unit
Bay Area, CA
      10-11-2016, 12:24 AM   #6
Mr_Jack
19x8.5 ET20(had 5mm spacer up front) 225/40/19 Hankook V12 EVo2
19x9.5 ET22 255/35/19 Hankook V12 EVO2
I also used to have M4 wheels
19x9 ET29 and used 12mm spacer 255/35/19
19x10 ET40 and used 10mm spacer 295/30/19
      10-11-2016, 09:58 AM   #7
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
Also my tires are 245/35R20, 275/30/R20. Told you the wrong specs
      10-11-2016, 10:45 AM   #8
D Unit
Mr_Jack... You have a serious wheel problem. BTW, did you like the Velgens or the Apex Arc 8s better? I believe Apex wheels are flow formed, TUV and JWL certified. The Velgens VM804s you posted are also flow formed, but not sure if they are certified.
You guys think the x1 can pull off 17s with 225/45 and 255/40 tires (.9" smaller than stock). I feel so attached to these wheels since I had them shipped from Germany and refinished in Cali. It's not like the X1 is a big car, right?
      10-14-2016, 04:45 PM   #9
M3 Adjuster
Albania
7905
Drives: 1M, X1 M Sport, E46 325ic
totally sweet. Actually might test fit my OEM wheels from my 1M for fun..
      10-16-2016, 07:38 PM   #10
PrematureApex
Drives: N55 X1, N54 135, s54 m3
OZ Ultraleggeras from our M3, 18x8/18x9, ET40. 12/15mm spacers with 225/255 tires. H&Rs w/B6s.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      10-28-2016, 04:34 PM   #11
neverdone
Drives: X5, 335, Ford Lightning, 63 me
winter mode! 18x8 manufacturer offset (specific to a 3 series) iForged Performance Daytona 2 piece wheels and Nokian Hakkapellitta 225/45/18
summer wheels to come once I do my B6/H&R setup.
      11-13-2016, 10:38 PM   #12
neverdone
well, no better time than now for summer wheels I guess lol
19x8.5/10 35/30 offset Work Euroline XR
      11-20-2016, 04:03 PM   #13
PJmacgee
Drives: '14 X1
@Mr_Jack, those tires look awesome, LOVE IT! That's exactly the look I've been trying for, smallish rims (17") with huge meaty tires. Is that size right, are those really 275 width R17 tires on there, and they fit okay with no spacers?
wheels - Apex
spacers - none
      01-31-2017, 10:36 AM   #14
cwylie
Drives: 2014 X1
Looking to put some 19's on the wifes X1. Whats the widest I can run fun and rear? I see Mr Jack has 295's but it sounds like its a pretty tight squeeze. Would a 275 rear 255 front be better?
      01-31-2017, 11:59 AM   #15
Gamb1t
Gamb1t's Avatar
Drives: 330i,X1,Z4,Solstice GXP, RX-8
I'll contribute. Winter set.
username - Gamb1t
wheels - BMW 5-series E60 Style 138
size and offset - 17x7 ET20. Abit aggressive offset for a flushed look.
spacers - None
tires (size and brand) - Triangle Snow Lion TR777 225/50/17
suspension -Stock
clearance - No rub anywhere.
      02-03-2017, 11:10 AM   #16
PARTS@STBMW
PARTS@STBMW's Avatar
2680
Great thread!
      03-05-2017, 07:14 PM   #17
tony3series
Drives: 2013 BMW X1 35i M-Sport
- Username - tony3series
- Wheels - BMW style 355
- Size and offset -
Front: 8"x18" ET30
Rear: 9x18" ET 41
- Spacers - None but thinking about getting 15-20mm rear & 12.5-15 front
- Tires Size -
Front: 225/45/18
Rear: 255/40/18
Brand: Sumitomo HTR A/S P02
- Suspension - Stock Msport.
- Clearance, does it rub? - Well it's stock Msport so no rub yet HaHa
I ordered B12 kit with Eibachs & Bilsteins. Should give a 30mm drop. Will post pics after installed. Also.. thinking about getting some VMR V710's 18x8.5 ET 20 front and 18x9.5 ET 22 rear.
      03-15-2017, 10:33 PM   #18
Westies
Drives: 2013 X1 35i M sport
Just picked these up, got a deal I couldn't pass! style 166 off an E60 M5
19x8.5 et12, 19x9.5 et28
The front offsets are obviously pretty low but I think (hope) they'll fit without any real issues.
I'll be test fitting them in the week or two before I order tires. Will do an "official" post once I get them on and drive them!
2013 MG X1 x35i M Sport
      03-16-2017, 05:49 PM   #19
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
The front offset is way too low. They will stick out pass the fenders for sure.
      03-17-2017, 02:39 AM   #20
Westies
Yeah, I was a little concerned; but based on others' setups, I saw these and figured I'd give it a try. I've always admired 166's. if I don't like the fitment I will just sell them and hopefully make a little $.
it's stock M sport suspension so I'm not worried about rubbing. The front offsets are only a few mm (literally around 0.04 of an inch) lower than some of the other set ups on here, but a narrower rim. So I'll see how the test fit goes.
But even if I hate it, no harm no foul. I still have the oem 225's.
      03-17-2017, 09:02 AM   #21
kiloTHREE
Drives: '13 xDrive28i
It's going to be quite cheeky.
Here's 18x8 et13 with just a slight poke on the front.
Your going to be 7mm farther out, so basically the entire lip will be outside your fender, but that's about it.
      03-22-2017, 04:06 PM   #22
Gamb1t
Gamb1t's Avatar
The poke will be more pronounce once you wrap corresponding width tires. At that width you're looking at around 245 for fronts and 265-275 for rears.
xbimmers
