M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > F10 M5 DIY Guides
      09-27-2016, 01:10 PM   #1
straightpipeguru
Drives: F13 M6
F10 M5 and F12/F13 M6 Front Brake Pads replacement
Hey guys
I just did a front brake job, trying to get rid of the squealing with aftermarket brake pads, lets hope it does help at least.
This is what the brakes setup looks like after taking the rim off
Remove the top and bottom pins, just tap it out as shown
Remove the nut that is holding the caliper on (14mm)
Compress the pads to remove the caliper/pads setup
Once the caliper is out, remove the pads, clean the piston area, lube the contact points and install the new pads. Everything else is pretty much reverse of installation, its pretty easy!
      09-27-2016, 01:31 PM   #2
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Drives: 2013 BMW M5 | MSR Stage 3
Nice DIY! Thanks for the info
*** SOLD *** 2013 BMW M5 | Space Grey | MSR Stage 3 Tune | Catless Downpipes | MSR Intake and Charge Pipes | MSR Exhaust (Prototype) | Vorsteiner Rear Diffuser | RW Carbon Front Lip | RW Carbon Trunk Spoiler| Vorsteiner VS-310 Forged Wheels | Escort 9500CI w/Laser Jammers
      10-02-2016, 11:00 AM   #3
apexlocator
Drives: 2014 M5
Thanks. What's the torque spec for the 14mm?
      10-23-2016, 07:09 AM   #4
E90Fleet
South Africa
1312
95Nm
BMW if you are reading, I need a job, Please.
      01-25-2017, 07:50 PM   #5
Demon Barber
Drives: 2018 M5, 2022 911 Turbo S
Nice DIY. Much appreciated. I will add that Cool Carbon front pads, leaving rear stock, completely eliminated all brake squeal for me. And, much less dust. I also have not noticed any decline in pedal feel. Very happy I made the switch!
      02-04-2018, 03:16 AM   #6
jaylee619
Drives: 2014 Black Sapphire M5 competi
Originally Posted by straightpipeguru View Post
Hey guys
So you didnt swap out the rotor? Sorry photos dont show. I have 9mm front left and 11mm rear and it squeals like holy hell. BMW told me i dont NEED a brake job but only a brake job would fix the sound.
Said i have a lip at the top of edge of the rotor and when the brakes get hot it is causing the noise.
What pads did you use and think I should try just pads for now?
gdavis34.50
      02-04-2018, 11:22 AM   #7
Demon Barber
Cool carbon pads on the front completely eliminated my brake noise. I left rear OEM. I also have a lip on the edge of my rotors, but I didn't change them, and have had no problems. Much less brake dust.
Looks like ECS stopped selling them for the F10 M5, but European auto source appears to sell them, both front and rear.
      04-05-2018, 01:54 PM   #8
Jasoneo5
Drives: 997 TTs, GS-F, RS6, M6 GC-sold
Thanks so much! Did you re-use the factory backplates? If so, did you apply any type of anti-sqeak lube?
      07-07-2018, 10:23 PM   #9
gazosnic
Drives: bmw m3
What is needed to have the calipers completely removed? I am thinking of taking mine to get powder coated in another color.
      02-22-2019, 02:42 PM   #10
Phox
Drives: 2014 F10 M5
So you don't need to program the calipers after pad replacement?
I just paid like $1500 for the rear brake job. My fronts make a lot of noise.
      02-26-2019, 04:54 PM   #11
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
if you're talking about the conditions based servicing counter, you should reset it after you replace the wear sensors.
Typically, you replace the sensors when you replace the pads.
      03-09-2019, 05:02 PM   #12
@straightpipeguru. Explained to so easily and will tackle it myself at pad change time, doesn't look like a big deal doing them.
      08-22-2019, 08:58 AM   #13
MichiganMan
Drives: 2013 BMW M5
Hey guys
Thank you for the write up! I am going to be doing this next week, and was curious if you were able to re-use the springs and pins from the previous pads (assuming no damage when removal). Its quite expensive for new hardware, more than the pads themselves. Thanks!
      02-03-2020, 02:02 AM   #14
maka2545
Drives: BMW M5
https://xn--12clam1a5anocac0ih9a9hd9ed4cme4vsg8a.com/
ฐานรองที่นอน เตียงนอน เตียงลิ้นชัก
      02-09-2020, 08:53 PM   #15
JinEBM
Drives: BMW M3
Just wondering if anyone know the brembo part number for the pins and retainer set for the front calipers?
      05-27-2020, 07:03 PM   #16
m5teven
Drives: '15 CP M5
2015 BMW 528i  [0.00]
2013 BMW M5  [0.00]
2014 BMW 550i  [0.00]
2015 BMW CP M5  [0.00]
Hello, I'm wandering if anyone has found a good DIY for taking the rotors off as well? I'm looking for a DIY similar to this one with the pics and instructions.
      05-30-2020, 08:37 AM   #17
2Live4
Drives: 2015 M5
I haven’t taken the rotors off yet. But I’m sure it’s a basic design with two bolts holding the calipers. Once the calipers are off, you should be able to remove the rotors.
2015 M5 CP - Alpine White - My joy ride
2013 LS 460 - Pearl White - Wife's
2007 M5 - Black Sapphire - sold
      03-23-2021, 02:41 PM   #18
Ferndezmond8
Drives: F10 M5
I just performed this service. The rotors are held on by two allen head screws. Very easy to do after you remove the caliper
      08-13-2021, 11:37 AM   #19
kushtrim
kushtrim's Avatar
Albania
176
Drives: AW 528 xdrive (AW 335i coupe s
2008 335i coupe  [10.00]
Is there a specific way to do the rear ones, I'm being told the rear is complicated because of the hand brake supposedly there is a specific way for that.
M-tech front and rear bumpers /M3 style side skirts/gloss black painted roof/ black window trim/Matt black grill/35%tints/4"dimisaTips/CF splitters/M3 style trunk spoiler/VMR V70s/JB4/BMS dci/AMS FMIC/H&R sport with BMW performance shocks.
Thanx Sal and he's crew@AutoCoutureMotoring
      08-13-2021, 08:08 PM   #20
arucano
arucano's Avatar
Drives: 2014 M6 Grand Coupe CP
2014 BMW M6 GC  [10.00]
there are some DIYs on YouTube. search with "BMW rear brake pads with electric parking brake" You don't necessarily need the software to retract the electric hand brake. You can do it manually once you remove the motor.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
m5post
