09-22-2016, 10:08 AM | #1 |
Rep 2,808
ACC - can you turn it off?
Ok so I specced Auto Cruise Control. I have to be honest its the only let down on my F36 as I love every other option. I find ACC like binary. Its either on or off and nowhere in between. When someone pulls in it takes an age to do anything and then wham accelerates like mad. When someone pulls out it slams on the brakes even though they are far ahead. I can only imagine what others think behind me. I've tried adjusting the distances using the control on the steering wheel but for £800 or whatever it was I don't rate it.
Which begs the question can I have normal cruise control instead? I don't see a way to turn the ACC feature off. Any tips? Ta
Current: G26 i4 M Sport Pro, Tech Pk, Sunroof
Previous: 2016 440i MPPSK, 2014 330d Saloon F30, 2013 Audi S4 Avant, 2011 Mercedes C350 |
09-22-2016, 10:21 AM | #2 |
Rep 5,681
I had active cruise on my E92 335i (bought second-hand) and, while I know some people like it, I thought it was absolute rubbish and there's no way I'd spec it on a new car. Sadly, though, I'm not aware of any way of turning it off; think the best you can do is to have it set so it looks as far ahead as possible but I don't think you can disable the active bit....
09-22-2016, 10:25 AM | #3 |
Rep 1,926
I've used similar systems from other Manufacturers and always found you have to work around them, which defeats the point in my book.
I know there's a few on here that swear by it, but I'm certainly glad I didn't specify it.
F31 340i | GS with CR & Ash Grain Trim | M Sport+ Pack | Prof Media Plus Pack | Interior Comfort Pack | Leather Dash | Folding Mirrors | Pano Roof | Elec Mem Seats with Lumbar | Adaptive Suspension | Comfort Access | Reverse Cam | Surround View | SLD | Rear Sunblinds | Folding Headrests | Model Designation Delete | Trim Designation Delete | MPPSK
09-22-2016, 10:43 AM | #4 |
Rep 8,636
Once you know its nuances its brilliant. I do miss it on the m140.
You can set it into normal cruise with brake mode without the radar, I did it on my 06/2014 car but only once or twice to test ages ago. IIRC its a long press on one of the distance control buttons. Last edited by SkyJawa; 09-22-2016 at 10:51 AM.. |
gr4z1135.00 |
09-22-2016, 10:48 AM | #5 |
Rep 375
Yep just reduce the radar distance to zero and hold the button for a short time and you have normal cruise.
I do like ACC in certain circumstances but other times it is rubbish. Dave.
F31 335d xDrive MSport touring.
Sapphire black with Coral leather. Ordered 27\03\2015, Build Finished 17/4/2015. Collected 20/05/2015. |
09-22-2016, 10:51 AM | #6 |
Rep 2,808
It's not bad in heavy traffic and only on dual carriageways or motorways. In light traffic or single lanes I find it useless and a hindrance actually. Sometimes dangerous if someone is too close to you at the back and it slams on the brakes.
Will try what you suggest. Thanks
09-22-2016, 10:54 AM | #7 | |
Rep 5,681
09-22-2016, 10:55 AM | #8 |
Rep 9,709
As SkyJawa has correctly mentioned, a long push on the distance adjust button turns off the active part.
You do have to learn some little tricks and help it out from time to time, but it does show how far artificial intelligence needs to come before we truly get self driving cars. |
09-22-2016, 10:57 AM | #9 | |
Rep 2,808
09-22-2016, 11:58 AM | #10 |
Rep 1,215
I'm with the OP on this, I can't stand the thing. As before, long press of the distance button will turn it into normal cruise. Some tips include using Eco Pro to avoid harsh acceleration but the one I found most useful was taking control of the throttle whilst the system is still active. That way you don't hang back so far and you can also accelerate more sooner whilst the car in front of you pulls over. It's not perfect though. The only time I found it useful was on quite motorways in Croatia (!), plenty of time to do its thing and hardly any traffic behind to bunch up and wonder WTF you're doing. Wouldn't spec it again.
09-22-2016, 12:02 PM | #11 |
Rep 527
I'm getting used to this now. For instance, I like the way it can tell (presumably by measuring the change in distance) if I've pulled out behind a faster car on a motorway.
Let's say a car is going 90 to my 70, I can judge his rate of overtake, and pull out with a reduced gap, knowing within seconds he'll be well clear. It won't slow me down then and will actually begin to accelerate if below the set speed, albeit at a slower rate than the other car is passing. I think the main thing is anticipation for the most part, and getting used to when the brakes will kick in at each distance setting, and where possible, making the maneuver before that point. It doesn't get around someone else pulling in front of you though, you're right there. Anyway, I suppose a case of ETTO. But as to turning it off, I thought you just pressed the button to the right of your right hand knee? The place where the little storage drawer would be if you'd specced the extra storage. It's what I've got. And if I press it so it is not lit as green (its default setting) then it behaves just as standard CC. This not the same in the 4 series?
Current = 2019 G32 630i M Sport+
Previous = 2016 F31 330d Touring M Sport+ & MPPK |
09-22-2016, 12:08 PM | #12 |
Rep 1,215
I thought that just turned off the anti-collision setting?
09-22-2016, 12:08 PM | #13 |
Rep 738
This a dissapointing!!
I had ACC on my S4 (bought used with it on) and exactly like the op, thought it was too basic and not really comfortable to use. This was a 2010 car and I'd hoped it had moved on by know ..... obviously not!!
X3 M40i Carbon Black
09-22-2016, 12:30 PM | #15 | ||
Rep 9,709
The other little tip is if you are coming up to a car you intend to overtake, indicating overrides 'car present in my lane' which allows you to get much closer (and start accelerating) without the system locking on to the speed of the car in front. Although I appreciate most BMW owners won't have experienced this trick....what indicators |
09-22-2016, 03:24 PM | #16 |
Rep 32,881
I think you just need to change your expectations of it, it isn't an auto pilot.
What it is, is cruise control that you don't have to stop using if there is vehicles in front of you, which considering there's almost always vehicles in front, is brilliant! If something pulls out though, brake and then hit resume. If the car in front turns off then just accelerate yourself until it loses the car in front. |
GaryUFM189.00 |
09-22-2016, 04:14 PM | #17 |
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
I didn't don't like it at first and then used it in standard mode, but then you realise that all those situations where ACC doesn't work that well are just situations where standard cruise just doesn't work at all.
I've now got so used to It that when I came to spec my second F30 it was then one of the first things on the spec sheet. I spend a lot of time on congested motorways and stop start traffic where it makes life very easy though.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
teaston10998.00 |
09-22-2016, 04:36 PM | #18 |
Rep 1,580
I had it on a Mk7 Golf I used to have. Hated it. Its only any use if you want to go at exactly the same speed as the car in front. And in reality how often is that?, because the car in front could be going slower than you want, or changing speed unnecessarily. What I hated most about it though was when travelling in either lane two or three, and gaining on a slower car in front, its often the case that that car is passing another vehicle and is about to pull in after completing the pass. I can see that he's pulling in and will have cleared my lane before I catch him, but the bloody radar CC slows the car completely unnecessarily
G20 320dx. Every option except a tow bar
'20 Subaru XV 2.0. Gone; F30 335dx, F30 330dx, F21 LCI 125d, F48 X1 20dx, F10 520d |
09-22-2016, 04:43 PM | #19 | |
Rep 5,681
ETA: While I was typing I see 73henny has made exactly the same point! |
09-22-2016, 04:51 PM | #20 |
Rep 19,982
Totally agree it can frustrate at times, but those times are not really times when normal cruise would be so much better. In that situation I would just tap the cruise off, then re-engage, or else put my foot on accelerator. I know that begs the question of why bother, but it's active cruise, not autonomous driving!
So for me on most long motorway journeys it's a real boon, and gives a lot of reassurance that if you're distracted for a second at the wrong time then it's also got you covered, hopefully avoiding the all too common rear end shunts I see every day. Also, in the slow moving crawl at rush hour then it's superb. But I'll do 35k miles across the two cars this year, so my circumstances justify it more than for others I'd guess.
09-22-2016, 04:52 PM | #21 |
Rep 8,636
A combo of the ACC on our Octavia with the BMW variant would be pretty good.
What I really miss from the BMW on on the Skoda is it brings you to a complete stop and stays there. Then to move off you either press resume on the wheel or tap the accelerator. In the Skoda once you've stopped it tells you to activate the brake and if you don't after a few seconds starts moving again. Once on the brake you have to start off again on your own and re-engage the cruise once moving. However once moving the Skoda/VW variant is much more configurable and better. |
09-23-2016, 02:35 AM | #22 |
Rep 2,808
Thanks for all these tips guys. It's good to know I'm not the only one frustrated with ACC.
Will tinker. Especially thanks for the tip about using the indicator!
