Reliable modifications
09-19-2016, 08:56 AM | #1 |
Rep 68
Hey guys, I just picked up an E90 335xi with only 32k on it. I want to begin modifying my car but looking to take a different approach than I'm used to. I know these cars have issue with the turbo wastegate and HPFP, so I want to be able to modify my car the most reliable way possible to avoid quicker fail of any parts. I know a tune, exhaust, and intake are inevitable, but I wanted to know any good upgrades to further enhance the reliability i.e. upgrading cooling system, intercooler, oil catch can etc. What are some upgrades to help here?
09-19-2016, 09:01 AM | #2 |
happy.
138
Rep 464
Get a walnut blast, new plugs and coils, find out what index your injectors are and possibly replace/upgrade them, charge pipe/dv/bov/downpipes can wait until you're pushing higher boost with a tune. check out the brakes/suspension and ensure all is in good working order. all i can think of at the moment - popular topic though so a bit of searching will help otherwise i'm sure many more will chime in shortly.
and as the forum members usually say - toss 5k into a 'fucked up N54 emergency' fund!
'09 Jet Black E90 335i | BMS DCI | Forge DV | VRSF CP, DP, 7" FMIC, Exhaust | MHD Stg 2 / 93 Oct | Koni Yellow / H&R Sport | Mooooarrrrrr
this list is getting too long..... |
09-19-2016, 09:05 AM | #3 |
Rep 3,554
most reliable mod is a steering wheel cover. 2nd most are seat covers.
Everything else will put more strain on the car. Modding =/= reliable. |
09-19-2016, 11:07 AM | #4 |
Rep 96
Not really true... Things like a upgraded FMIC/intake/inlets/dps all will put less work on the engine and turbos and potentially make them more reliable, its only whenever you put on a aggressive tune and start making a lot more boost when you can hurt reliability.
09-19-2016, 11:08 AM | #5 | |
Rep 3,554
09-19-2016, 11:14 AM | #6 |
Rep 554
Drives: 2013 335is E93 6MT
Jeez, he said 32K, not 132K. Those are all nice, but he probably doesn't need any of that yet. Get MHD, put the stage 1 map on, and see if there are any misfires. If so, then replace the plugs, if not, carry on with the FMIC and DPs.
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
09-19-2016, 11:25 AM | #7 |
Rep 386
Drives: 08 535xi 11 328xi
Tune or not, if the injectors and hpfp are original, they will most likely fail. If the injectors are anything less than index 11 they will probably fail. I purchased my 08 535 a year ago with 60k and the pump was already shot and needed 6 injectors, 2 were definitely leaking and the rest I ended up replacing because I didn't want to deal with it once I put the jb4 on it. I would not suggest replacing them if you are not having problems, wait until they fail and then worry about. Put some money away now and save up for it when they do start failing.
09-19-2016, 12:47 PM | #8 |
Rep 113
An upgraded PCV valve and an oil catch can help reduce the amount of oil that go through the intercooler and charge pipe and burn up on the intake valves. When I started upgrading parts my intercooler and charge pipe were both coated in oil. You'll see people talking about walnut blasts to remove the carbon deposits on the intake valves from the oil that burns up on them. It can rob the engine of some power up top and cause misfires and rough idle. On a stock engine it’s not really a matter of if you will need to get it done but when, and where I live a walnut blast runs around $400 so reducing the frequency you need to clean the intake valves could save you money in the long run.
Some people have reported no oil issues after just upgrading the PCV valve (Rob Beck sells one for around $40) and some (myself included) have gone one step further and added an oil catch can. I poured about 30ml of oil out of my OCC last weekend while others never saw a drop of oil in theirs so YMMV. BMS sells a popular one that mounts near the firewall, I bought a Mishimoto one because it mounts at the front of the car where the air should be cooler and it’s more convenient to have a quick look to see if oil has collected. At the time I bought my OCC there was a thread where some people were complaining of oil seeping through the hoses of their BMS catch cans after prolonged use. It didn’t seem that the issue was ever addressed which also put me off a bit. Some have gone a step further with dual catch cans (and more) but that’s beyond my level of expertise. You can find those discussions if you’re interested but the 2 above are the most common fixes for N54 oil problems. As others have mentioned catless downpipes, an upgraded FMIC and inlets and outlets have their place in reducing turbo backpressure, keeping intake air temps down and decreasing turbo wastegate duty cycle. An upgraded metal charge pipe is a good idea if you plan to increase boost pressure as the stock plastic charge pipe can either pop off or break. Some have had issues at stock boost levels while others have run the stock pipe at much higher levels without any problems so again YMMV. |
09-19-2016, 01:08 PM | #9 |
Rep 68
Thanks for the input guys, that's very helpful. My goal is put a few bolt ons and upgrade some parts to allow better airflow to prolong the life on the turbos and any other components related to them. I'm NOT looking for 500-600 hp but more of a conservative tune and upgrades to also be reliable. I don't race just an enthusiast looking for a little bit more power and sound. How often should I do the Walnut Blasting? Are there any recalls on the HPFP or Injectors or Turbos? Thanks.
09-19-2016, 01:09 PM | #10 |
Rep 68
Do you prefer MHD over JB4 and COBB? Is one more reliable then the others? Cheaper?
09-19-2016, 01:45 PM | #11 | |
Rep 554
As for JB4, there are some who contend that MHD with a JB4 backend flash is the best of both worlds, while others contend JB4 (at least by itself) affords inconsistent power. Regardless, you're not going to find all that many people who get MHD and then get a JB4. Most already had a JB4 when MHD hit. MHD alone is more than sufficient. It's also the cheapest option, particularly if you already have an Android device. (All three options are reliable.)
09-19-2016, 02:16 PM | #12 | |
Rep 68
09-19-2016, 04:02 PM | #13 |
Rep 554
Yes, through the OBD port, and it's Android only because of the iPhone's self-imposed limitations. Inexpensive (~$50) Android tablets work fine, though. There is some info on them in the main MHD thread, although you might have to dig to find it due to the size of the thread. I have a custom MHD map from a third party tuner on my car right now. The first MHD tune I had was the stage 1 map offered directly by MHD.
09-20-2016, 07:15 AM | #14 | |
Rep 68
09-20-2016, 07:29 AM | #15 | |
Rep 554
09-20-2016, 10:55 AM | #16 |
3441
Rep 79,211
Walnut blast every 35K ideally. Minimum every 50K for optimum performance.
Spark plugs every 25K when tuned. For peace of mind and the utmost in reliability consider 6 new injectors, index 12 revision. Also inspect your valve cover for leaks or cracks. Prone to crack around 45K miles for some. FMIC is the first recommendation after a tune. That helps keep the engine and turbo's happy. Also you'll want a charge pipe as those are prone to crack once tuned and as they age. |
09-20-2016, 11:09 AM | #17 |
Something Danger Zone
41
Rep 257
A charge pipe+BOV, a better intercooler, RB PCV valve+Cap, Steering wheel cover and the felt for the Windows (prevent scratching).
I'd also recommend upgrading your brake pads to low dusting pads and higher temp brake fluid when you need to flush it. A walnut blast+Plugs would be good about 50k miles. |
09-20-2016, 04:37 PM | #18 | |
Rep 68
09-20-2016, 05:07 PM | #19 | |
Rep 128
Great job getting a car with that low a mileage! As for now, I would try to drive it as much as possible. With a car that old with such low mileage, maybe some of the rubber bits and hoses have decayed over time. The original parts were the disaster on these cars, obviously over exaggerating but yea.. so the only thing I am worried about is that you're on the earliest revisions on these things and now they may fail when you're out of those extended BMW warranties But obviously starting with MHD will show you all the weakness a lot sooner so go for it! The intercooler is always a great bet as well. It really just depends on how much power you're going to run, How much do you want to cut the front bumper, and if you care about it looking stock or not. But read the super long intercooler thread on here, lots of suggestions for intercoolers! Good luck and welcome |
09-20-2016, 06:12 PM | #20 |
2095
Rep 43,350
Another idea, anything that will reduce WGDC like a free flowing intake/inlets or a larger less restrictive intercooler/downpipes will increase the life of the turbos since they can operate at lower wheel speeds.
09-21-2016, 07:35 AM | #21 | |
Rep 68
09-21-2016, 07:48 AM | #22 |
Rep 2,590
Reliable and N54 should never be placed in the same sentence unless you're saying, "The n54 is extremely reliable at having problems"
lightmanek116.50 bradsm87594.50 |
