E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Oil leak need help detecting!
      09-18-2016, 12:51 AM   #1
Royalty_bimmers
Drives: 08 bmw 335
Have an oil leak but dont know where its coming from. I have a 07 335i sedan n54 with 103k i have never changed the valve cover gasket which im pretty sure its due for but i have a leak under the car near the downpipes and near oil pan. I have changed the oil pan gasket at 80/90k. There was oil on a bolt right next to the downpipes and oil leaks off the downpipe to the floor. Any guesses ? Could it just be the valve cover gasket leaking to the downpipe and that bolt ? Thanks for the help
      09-18-2016, 12:59 AM   #2
Royalty_bimmers
Drives: 08 bmw 335
Also oil level doesnt seem to be going down as i check it on the display
      09-18-2016, 01:47 AM   #3
pits200
Drives: 09 335i X-Drive Black Sapphire
Pics help
      09-18-2016, 11:09 AM   #4
Royalty_bimmers
Drives: 08 bmw 335
Couldn't upload
      09-18-2016, 11:39 AM   #5
TrollToll
TrollToll's Avatar
654
Drives: 535i
Couldn't help detect oil leak
      09-18-2016, 12:09 PM   #6
Gohan335i7
Drives: 335i
2010 335i  [10.00]
My guess would be Oil Pan Gasket again, however, since you haven't done the VCG I would go ahead and do that, also the OFHG if budget allows.. I think you need to use a desktop to upload pictures on this website just so you know .
      09-18-2016, 02:29 PM   #7
Royalty_bimmers
Drives: 08 bmw 335
Okay and i tried putting photos it says a token is missing something like that. Oil filter gasket a diy?
      09-18-2016, 02:35 PM   #8
Needbmwpartzz
Needbmwpartzz's Avatar
851
Drives: 2009 bmw 328i x-drive
Follow the drip!
      09-18-2016, 02:56 PM   #9
Royalty_bimmers
Drives: 08 bmw 335
I did its leaking from the far end of the valve cover gasket the last bolt near the cowl filters go but leaks all the way down to the down pipes and some bolt thats right next to thw downpipes but dont know if theres another leak down by the downpipes or turbos ?
      09-18-2016, 05:17 PM   #10
AndrewA
Drives: E90 M3
2007 BMW 335i  [0.00]
Is your Oil filter housing gasket or oil cooler gasket leaking? If not, it can be Valve Cover Gasket or Rear Main Seal
      09-18-2016, 10:09 PM   #11
beeming
Drives: e90 335i
Rear main seal? Mines is leaking and I used to go through a quart a month but has since gotten much better. Was quoted about 1.5k to do the job.
      09-19-2016, 09:29 AM   #12
Jeef
Drives: AW E92 335i
From the dealer?
      09-19-2016, 10:20 PM   #13
beeming
Drives: e90 335i
Originally Posted by Jeef View Post
From the dealer?
I got it quote almost 2 years back from dealer and Indy if my recollection is correct dealer was 3k and Indy 1.5k.
      09-19-2016, 11:19 PM   #14
Royalty_bimmers
Drives: 08 bmw 335
I think mines my valve cover gasket which is leaking down to the downpipes ima try that out first never has been changed. Hate the smoke coming out of the engine. I hope its that.
e90post
