03-31-2008, 04:12 PM | #1 |
Rep 266
///M roady 235/265 on stock rim
Hi all,
I need some new rubbers and would like wider tires.. I am currently thinking about 235/40-18 (front) and 265/40-18 (rear) on stock rims. any fitment problems? suggestions are welcomed. Thanks..
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual 2006 BMW 330i 6spd manual - gone |
03-31-2008, 04:23 PM | #2 |
Rep 815
Why go with 40's instead of the stock 35's in the rear. That'll add about an inch of diameter. While I suspect that it will fit, your acceleration will suffer by about 4%.
>> Oops. I'm wrong. See below. Last edited by vachss; 03-31-2008 at 05:05 PM.. |
03-31-2008, 04:28 PM | #3 | |
Rep 266
225/45/18(front) and 255/40/18(rear) are stock on the M roady.
2009 BMW X5 4.8i
03-31-2008, 04:44 PM | #4 |
Rep 815
OK, thanks for teaching me something. It never occurred to me that BMW would put more aggressive (lower aspect ratio) tires on the non-M, but I guess that's what they do. I guess this compensates somewhat for the higher rear end gearing of the M (3.62 vs. 3.46-3.23 for the non-M).
PS. Given that I wouldn't think the OP would have any trouble fitting the slightly wider tires he's considering. |
03-31-2008, 04:45 PM | #5 |
More than you can afford pal....ferrari
180
Rep 1,471
i was thinking of running the same setup. Im pretty positive they will fit the stock wheels. Not sure about the 40 offset all around. We need more tire gurus out here
04-01-2008, 11:57 AM | #7 |
180
Rep 1,471
04-01-2008, 12:13 PM | #8 |
Rep 266
I emailed Gary@tirerack yesterday, he also is the moderator of E90post Tire and Wheel section. Hopefully, he can shed some light on this for us.
2009 BMW X5 4.8i
04-01-2008, 01:23 PM | #9 | |
Skull Squadron Leader
304
Rep 2,031
Here's your bible. http://www.carbibles.com/tyre_bible.html |
04-03-2008, 10:17 AM | #10 |
Rep 266
thanks guys. I ordered Goodyear Eagle F1 Asymmetrics 235/40-18 and 265/40-18 for my stock rims. hopefully there won't be any rubbing. I will let you guys know later.
2009 BMW X5 4.8i
04-04-2008, 04:01 PM | #11 |
Rep 7,294
Correct me if I'm wrong, but the diameter of that setup does not match stock, so the speedometer will be off by a few percent. Does this change the way DSC behaves?
04-04-2008, 10:53 PM | #12 | |
Rep 266
the diameter change is still less than 3%, so it shouldn't cause any problem with DSC.
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual 2006 BMW 330i 6spd manual - gone Last edited by runnerx; 04-05-2008 at 11:15 AM.. |
