E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Meth Log
      09-13-2016, 07:26 PM   #1
jockdeeznutz
Drives: E92 335i
Meth Log
After having issues installing my BMS Meth kit, I got finally got it running. How does my log look? Thanks
http://s000.tinyupload.com/download....08744083634241
      09-13-2016, 07:50 PM   #2
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Send the log to datazap.me
      09-14-2016, 02:46 AM   #3
jockdeeznutz
Drives: E92 335i
Here are my logs. I started my Meth add at 40. Seems like I'm not hitting pass 15 PSI? I'm runing N54 FBO(BMS DCI, Downpipes, VRSF 7", JB4 G5 W/ 32/4/2 Firmware) No codes.
http://datazap.me/u/jockdeeznutz/log...log=0&data=1-4
      09-14-2016, 10:32 AM   #4
Maybe I missed it, is there a 3rd gear log in this?
If not, get on the highway and find a clear and safe area to log 2500 RPM to 6500 RPM in 3rd gear only at wide open throttle.
Don't log anything else.
      09-14-2016, 11:50 AM   #5
jockdeeznutz
Drives: E92 335i
I can't find the correct log but I will log a 3rd gear pull tonight and post results. Thanks
      09-27-2016, 12:16 AM   #6
jockdeeznutz
Drives: E92 335i
Finally had some free time and did a 3rd gear WOT as you requested. Can you take look at this? Boost add. was set at 50 also. Thanks
http://datazap.me/u/jockdeeznutz/meth?log=0&data=1-4
      09-27-2016, 09:49 AM   #7
Looks good, you have more room to turn up the boost another 2 psi if you want.
      09-27-2016, 10:20 AM   #8
jockdeeznutz
Drives: E92 335i
I thought I had a boost leak too? But I guess everything looks good. I'll turn it up a little Thanks!
      09-27-2016, 10:23 AM   #9
It is a bit off from target but I'm not too familiar with JB4 and if that aspect is normal or not.
Are you throwing 30FF?
Check for leaks of course.
      09-27-2016, 02:34 PM   #10
jockdeeznutz
Drives: E92 335i
Throwing no codes. I checked for leaks...nothing that I can find. I replaced all my boost lines with silicone ones, Checked my intercooler, replaced my boost solenoids as well. My wastegate rattles pretty bad so it could be just that. I"m about 107K miles on the stock turbos...I plan on going single anyways.
e90post
