E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Cannot achieve OBD Readiness (Catalyst)
      09-12-2016, 11:25 PM   #1
s0urce
Drives: 08' e92 335i 6MT
So, I'm trying to get the Catalyst Ready on my 335i. Emissions are failing me for this one check not being ready in CA.
I've done numerous drive cycles by the book, but after hundreds of miles I'm getting nowhere fast. JB4 is in map 0, I'm able to see the readiness states in INPA. Auto-clear 1-4 is OFF.
Car:
2008 335i
JB4 G5 ISO
STOCK DeePees
BMS Flash
There's such a mix of information floating around. Perhaps someone knowledgeable here could help me out.
Much appreciated!
      09-13-2016, 12:10 AM   #2
V8bait
Drives: e92 335i 6mt
The backend flash has the code disabled. You need to enable the code in the flash and run an O2 sim if you don't have cats.
      09-13-2016, 12:48 AM   #3
s0urce
Hm, so I actually passed with Catalyst ready 2 years ago with the current BEF. That leads me to believe it's enabled in the BEF.
The only changes since 2 years ago is that I've pulled the battery to replace injectors, and I've also upgraded the JB4 ISO Firmware.
      09-13-2016, 09:43 AM   #4
ferocity02
Drives: 2013 135is
Is autoclear on?
      09-13-2016, 11:14 AM   #5
s0urce
Originally Posted by ferocity02 View Post
Is autoclear on?
No
      09-13-2016, 12:53 PM   #6
V8bait
2 years ago in cali? Pretty sure it's disabled.
      09-13-2016, 01:48 PM   #7
andydna15
Drives: 335i
Flash back to stock and you should be good.
e90post
