E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > RB turbo set screws for head?
      09-07-2016, 01:44 AM   #1
specialist
Drives: 335i
I was tapping the head to close off oil passages to the intake.
used a Tap 10 32 then when i was trying to put the set screw in the hole i tapped i dropped the set screw in the head. soo pissed.
I wanted to know if there are oil passages to the pan or should it still be in the top of the head.
      09-07-2016, 08:37 AM   #2
homemade_f81
Drives: 2018 340i, 2020 M2CS
I would think it's still on top - there isn't an oil passage big enough for a screw that I can think of.
      09-07-2016, 11:36 AM   #3
specialist
Drives: 335i
going to try with a little magnet tn
      09-07-2016, 12:56 PM   #4
Turbo_power4ever
Drives: Fbo blacked e92
damn that sucks. lol good luck
      09-07-2016, 01:30 PM   #5
sirdaft1
sirdaft1's Avatar
Drives: X5 & E90 WTCC Widebody Racecar
Ehhh... just start her up. It'll come out the tail pipe. Kind of like when a dog eats bubble gum.
Jklad421.00
      09-07-2016, 02:27 PM   #6
specialist
Drives: 335i
lol
i was think of taking that intake cam out. need to figure out what tools i need to find it
      09-07-2016, 03:02 PM   #7
TrollToll
TrollToll's Avatar
654
Drives: 535i
What about a screw extractor?
      09-07-2016, 07:03 PM   #8
NA55
Drives: 335i
Use a magnet or rig up a small diameter nylon hose to a shop vac and try to find it..
      09-09-2016, 01:38 PM   #9
specialist
Drives: 335i
I have used a magnet no luck.
Today i am going to rig up a shopvac to see if i can find it.
if i can't
My next actions will be brake clean everything and try to blow everything out, hopping it will may be if there are any holes to oil pan. Then i am going to drop oil to check it with magnet. after then turn motor slow to see if it binds up. I will do two cycles. then look again if nothing i am going to take the cams off with bmw tools.
fml .30cents is going to cost me $800 approx with buying the tools and new cam bolt and tensioner seal
      09-10-2016, 08:56 AM   #10
1fastt2
Drives: 335i
Have you removed the intake manifold to try to get to it that way? Have to scoped the combustion chamber through the spark plug hole? That's where I would start.
2008 e92 335i 6MT - Fully Built Motiv Closed Deck Conversion. Everything else that goes with it.
      09-10-2016, 10:04 PM   #11
specialist
Drives: 335i
you think it would of went in the combustion chamber. i don't think there is an entry point from the head only if spark plugs/ intake mainifold was on.
So i have bought the tool i am just waiting for the bmw tool it will allow me to take off the intake cam and look.
I think i will have to but a new washer for tensioner and new cam bolts and cam cap bolts? can any one confirm that? also am i missing anything?
      09-11-2016, 08:14 AM   #12
j1gilles
j1gilles's Avatar
Drives: 2009 335xi
I would just start it if you cannot find the set screw... If it is still up in the head I highly doubt that it will cause any issues.
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
      09-11-2016, 09:41 AM   #13
specialist
Drives: 335i
i am not sure how much space in the valve springs maybe the set screw would get stick in valve spring and float the valve and the valve hit the cylinder. but i don't know i am just thinking the worst before the tool comes
      09-13-2016, 10:43 PM   #14
specialist
Drives: 335i
if i take the cam shaft ledger bolt can i reuse them if so where can i get them deal will not sell them?
      09-15-2016, 10:57 AM   #15
specialist
Drives: 335i
ok almost complete I am safe to say that the set screw is not in the head. I pulled off the cams gears and cams to check also changed to the updated seals on the cams. so I hope to have it done soon. 1 month almost waiting for parts and tool to get this done.
      12-02-2016, 09:12 AM   #16
specialist
Drives: 335i
well not problems but of fell in the oil passage or I blew it out no clue the car is running strong tho. been running the car 2 month no problems
e90post
