MHD V7 Beta logging run
08-28-2016, 01:16 AM | #1 |
Rep 645
Just did a logging run with MHD V7 beta - stage 1 93. Car is an 07 6MT E90 with 100K miles. Turbos and injectors replaced at 60K, and has always been run stock. Just had an intake clean, new coils, plugs and Vanos solenoid clean. Vacuum system was also smoke tested and all OK. Boost solenoids were also checked and all OK. Compression tested and all at 170 psi.
Lots of timing corrections going on here - main cause of concern is that it's across all cylinders, some up to 7 deg. Any thoughts? Fueling looks to be OK? Have always run 93 octane, though the car does sit for a week at a time not being used. Not sure if that changes the composition of the fuel! http://datazap.me/u/kiwird/log-14723...10-11-12-13-23 |
08-28-2016, 01:52 AM | #2 |
Rep 3,726
Try stepping down a map to see if timing corrections go away. Gas quality might very well be an issue for you.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
08-28-2016, 01:56 AM | #3 | |
Rep 645
08-29-2016, 01:24 AM | #4 |
Rep 75
I would try a 91 Oct map and see if the timing cleans up just to quickly verify that you don't happen to have a bad tank of gas. Shit happens.
RIP10' A/W M-Sport-JB4-E85/93,50/50-BMS DCI-AR DP'S-Balck Kidney Grills-muffler delete-mm6 mesh18x8.5/9.5-Conti DWS 235/40 18, 265/35 18.
10'e90 a/w SportPackage-mhd e40 map- a/r dp's-vrsf charge pipe and tial blow off valve 95 civic-k24 block-k20 head-12.5:1 c/r pistons-drag cartel stg4 cams-ported rbc mani-q45 90mm tb-ssr headers- 3" exhaust, 300+whp, 2000 lbs. |
08-29-2016, 01:34 AM | #5 |
Rep 75
You mean 93 oct / 98 ron?
08-29-2016, 02:08 AM | #6 |
Rep 645
Ha ha yep! Here it's just '98'. I get the RON bit round the wrong way.
08-29-2016, 03:35 AM | #7 |
Rep 49
98 RON shouldn't be showing such severe timing corrections provided the fuel was not a bad batch. You could always go back to a V6 91/95 RON map to test whether it is a fuel octane or hardware problem.
08-29-2016, 03:39 AM | #8 | |
Rep 645
