E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Removed JB4 and Car No Longer Works
      08-27-2016, 03:12 PM   #1
REV.olution
Drives: 2007 335i, 2017 Pathfinder
Removed the JB4 Tuesday, drove well for one day.
Wednesday afternoon the car immediately threw:
Tranmission Warning Codes
AC Turned Off
Radio/Iscreen Turned off
DSC codes and error
Finally, the transmission wouldn't get out of Park
So, I opened the hood, disconnected the entire DME, changed the relay in the DME box, and went over every area with a fine tooth comb. Once again,
No bent pins in the DME
All wires are properly snug
All changes required by the JB4, including that green/orange cord swap, was intact
So finally, I went to autozone and had them replace my battery for me. I used my bavarian technic cord and reset the ecu and cleared the ECU 10x. I also let the car run for 30 minutes and simultaneously erased codes as they kept coming back. No luck.
Waiting for my BMW Appt on Wednesday but any suggestions would be appreciated.
BMS OCC, BMS DP, BMS DCI, ER Charge Pipe, Tial BOV, VRSF 7" FMIC, VRSF Additional pipe to charge pipe, Walbro Inline Fuel Pump, JB4 G4, Walnut Blasting, New 1-Step Colder NGK Plugs, Amsoil Motor Oil.
      08-27-2016, 05:15 PM   #2
TrollToll
TrollToll's Avatar
654
Drives: 535i
Terry's revenge
titium326.50
8Series12.50
feuer4275.50
whyzee1251678.50
      08-28-2016, 08:31 AM   #3
Sean978
Drives: 2007 335i 6MT SGM
hmmm.... didn't see you mention if you tried reinstalling JB4 to see if it fired back up with jb4 reinstalled or not.
      08-28-2016, 08:41 AM   #4
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Plugs are in the correct slots and completely connected?
feuer4275.50
      08-28-2016, 02:52 PM   #5
REV.olution
FIXED: Bad alternator. Voltage had spiked to 17.79 and was throwing bad generator codes and making everything else go haywire.
feuer4275.50
      08-29-2016, 08:28 AM   #6
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Glad it's fixed. Crazy how sometimes stuff happens at the same time but coincidences do occur.
feuer4275.50
e90post
