MHD E60
08-25-2016, 12:52 PM | #1 |
Rep 42
MHD E60
I have a 335is FBO currently using E40 map with stock fuel pump and car is running great.... just wondering if e60 on the stock pump is cool to use.
08-25-2016, 01:10 PM | #2 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
No, no, and no.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
08-25-2016, 01:24 PM | #3 |
Liberty or Death
60
Rep 90
Drives: 2007 E92 335i
My stock pump nosedives with 2-3 gallons of E85, I doubt any stock pump could handle E60. Not for very long anyway.
08-25-2016, 02:01 PM | #4 |
Rep 554
Drives: 2013 335is E93 6MT
I wouldn't go much above E30 on a stock pump. But I will tell you it's absolutely worth it to get the stage 2 LPFP upgrade from Steve at Fuel-It.
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
08-25-2016, 02:16 PM | #5 |
Rep 2,083
My stock pump was at it's limit with E40.
Also, the fuel scalars in the map are for E40. If change the fuel the trims will be out of whack. There might be enough room for it to compensate, but I wouldn't risk it.
2013 135is DCT Carbon Black Metallic |
08-25-2016, 04:42 PM | #6 |
Rep 946
He's probably talking about the new MHD E60 map, but it still isn't likely a stock pump can do it. Not with a 3 series at least.
08-25-2016, 04:45 PM | #7 |
BimmerPost Supporting Vendor
24198
Rep 190,805
Get the fuel it stage 2 kit and you will be able to run E60 maps
335NJ532.50 |
08-25-2016, 07:06 PM | #8 | |
Rep 2,083
Anyone know boost this targets? Risks on stock turbos? I've used the E40 map plenty of times and love it.
08-26-2016, 09:00 AM | #9 |
Rep 3,554
08-26-2016, 10:15 AM | #11 |
Rep 2,083
The risk is in the boost targets, not the fuel. Hence why I was asking what the boost targets are. Targeting 25psi on stock turbos is a great way to kill them quickly.
08-26-2016, 10:41 AM | #12 |
Rep 3,726
If its anything like my E50 map, 20 psi peak tapering down to 16 psi. Also likely increased timing compared to E40.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
denobd17.00 |
08-26-2016, 11:06 AM | #14 |
Rep 3,554
considering youd need to get one of the higher pressure tmap sensors to accurately target 25psi, im 99.9% sure they wouldnt do that for an OTS map
