Orings leaking at oil cooler housing hoses, again
08-25-2016, 11:06 AM | #1 |
Rep 175
So I replaced my ofh gaskets and the two orings where the hoses attach. Its been about three thousand miles and I have a drip coming from the hoses. Ive been wiping it down daily to make sure that where its coming from. Any pointers here ? O rings were brand new....
09-21-2016, 10:14 AM | #4 |
Rep 175
so I installed new orings and mating areas were clean of any debris as was before. Im still getting a leak from the right hand side hose in the pic. Makes no sense. Guess Im going to "black rtv" it. Anyone else have any ideas ?
09-21-2016, 10:36 AM | #5 |
Rep 723
Check the thermostat. I just had this fixed. Looked like the OFHG, on cleaning found that the thermostat was corroded
Here is what was replaced on mine https://www.ecstuning.com/b-genuine-...5q7RoC5Djw_wcB
2007 335i E92 MT | MFactory LSD | Diff Brace | MHD/Wedge Tuned| BL Coils | Stg2 lpfp BoostConcepts | VRSF DPs | VRSF 7" HD FMIC | DCI | VRSF CP | BMW SSK | Billstein PSS Coilovers | M3 Control Arms | Whiteline Rear SF Inserts | SS brake lines | Z4 35is Rotors | Hawk 5.0 pads | M219s + PSS | PE Mod -SOLD
2016 M4 F82 MT |
09-21-2016, 10:54 AM | #6 |
Rep 946
You still didn't mention if you lubed them before installation.
Chris@VargasTurboTech1933.00 |
09-21-2016, 12:10 PM | #7 |
Rep 175
no lube before install. Clean and dried with a rag. Theres really no way for them to get damaged during the install. Oring slides over inlet/outlet alum tubing and mates up with the bottom of the thermo housing. I can see with a mirror were its seeping out, maybe a couple drops during an hour drive. T
09-22-2016, 03:07 PM | #8 |
Rep 3,336
Drives: X5 & E90 WTCC Widebody Racecar
So you used brand new OE o-rings?
09-22-2016, 03:13 PM | #9 |
Rep 175
yep, both times. I took it apart last night a ran a fine bead of Black rtv on both sides of the o-ring and reinstalled. I'll take her for a ride or drive her to work tommarrow and see if stopped the leak. Makes no sense. I originally took the whole OFH off when I did my walnut blast and re-sealed everything with new oem gaskets. Its been six months and just started the drip.
09-29-2016, 11:24 AM | #11 |
Rep 175
yes sir, that was it. I ended up wrapping a white rag around the bottom side and drove around till it "bled" enought oil to give me an idea of where it was leaking from. Popped the cover off, slapped a bead of blk rtv on it and leak solved ! Thanks !
