E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Residue near fuel lines and injector
      08-24-2016, 12:22 PM   #1
squixs
Germany
109
Drives: BMW M2 Competition
Exclamation Residue near fuel lines and injector
Hi all,
A mechanic replaced my injectors for index-12's a couple months ago.
Today I removed my engine cover and discovered that on injector 1 and 3 there's a fair bit of residue (fuel?) between the fuel line and the top of the injector.
On the second picture, you can see a clear difference between how it should be (left) and how it is on the 3rd injector (right).
Are these injectors flawed or is the bolt simply not tight enough / missing a bushing?
Thanks in advance!
      08-24-2016, 12:58 PM   #2
specialist
Drives: 335i
i can't see the pics
      08-24-2016, 02:04 PM   #3
squixs
Germany
109
Still no pictures? They show fine on my mobile phone
      08-24-2016, 02:14 PM   #4
ucdbiendog
Drives: 2008 335xi E90
based on where it is, can't think of anything else it would be. does it smell like fuel?
      08-24-2016, 02:37 PM   #5
FCobra94
Guest
n/a
Drives:
Looks like oil to me. Is your oil cap leaking?
I had a little bit of oil on injector 3 too; a bunch of oil had also absorbed into the foam under the engine cover as well.
I swapped my original oil cap out for the newest version and no issues since.
      08-24-2016, 03:41 PM   #6
jwebb335xi
Drives: 2008 335 XI
Originally Posted by squixs
Hi all,
Thanks in advance!
Looks like oil; I'd expect fuel to mostly evaporate and be much cleaner unless is was a persistent issue in which case it would probably collect dirt..
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs
      08-24-2016, 03:53 PM   #7
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
This seems very likely. It sure doesn't look like fuel from the pics.
OP tighten them up and look at that oil cap area.
      08-24-2016, 03:56 PM   #8
bartbes
Drives: e92 335i
I had the same problem, picked up a new oil cap and it got better but stil seeping.
Think this might be your problem op.
I have an after market oil cap now so maybe that's why mine is'nt 100% sealed..
Wich one do you have fcobra94?
      08-24-2016, 04:10 PM   #9
FCobra94
Guest
n/a
Drives:
new oem version
      08-25-2016, 12:09 AM   #10
squixs
Germany
109
Thanks for the replies, Will look into the oil cap. But, how can there be oil on injector 1 when the oil cap is leaking? From what i remember that injector is not near the oil cap.
      08-25-2016, 07:39 AM   #11
FCobra94
Guest
n/a
Drives:
idk dude, maybe your valve cover is cracked, valve cover gasket is leaking, some other gasket is leaking, etc. You'll have to tear into it...can't diagnose this over the internet.
e90post
