E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Two new gremlins. Any ideas?
      08-19-2016, 09:04 PM   #1
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
#1 My boost logged 28 psi, which is what it's supposed to be, for a few seconds then dropped to 21psi. We don't think I have a boost leak. Could this be boost solenoid? Poor vacuum?
#2my csr started overheating and showing s radiator symbol after drIvins 5 hours today. Mostly highway on cruise control. It has a new radiator, hoses, and pump. I did notice s wet spot inside the car on the drive tunnel carper under the dash by the passenger foot area. Idk if it's related. Didn't smell like antifreeze. I let the car cool for a bit then temps dropped some. Then driving it after temps continued to drop and not climb. The thermostat is broken open but I can't see that being the issue.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
      08-20-2016, 08:57 AM   #2
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
      08-20-2016, 04:09 PM   #3
jjbmuu
4ut0strd4
Drives: 08 AW E92 335i 6 Speed
The wet spot is either a backed up a/c drain or a leaky evaporator, hopefully the first of the two.
      08-20-2016, 05:55 PM   #4
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
It's not the evaporator. A/C is cold as ice. Maybe heater core? It's a cooling system issue. Not an A/C issue
      08-20-2016, 09:26 PM   #5
whosdady
whosdady's Avatar
135
Drives: 335i Coupe
I'm guessing your CSF radiator is leaking. Maybe from a rock thrown up, a bad weld or a bad connection. It's likely very small. It's not related to the water in the footwell.
      08-21-2016, 08:35 AM   #6
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
I don't think so. There's some coolant residue by the chargepipe area too. Not much but there.
      08-22-2016, 06:10 PM   #7
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Any other ideas?
      08-22-2016, 07:43 PM   #8
ATH_M2
Drives: LBB M2
Did the overheat symbol on (thermometer) or just the radiator symbol? If it is just the radiator symbol then you may have a leak somewhere as suspected but not overheating yet or if you cant trace the leak maybe the wiring came undone from the coolant tank?
      08-23-2016, 07:15 AM   #9
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
It did it in stages. First rad symbol. Figured small leak. Couldn't see anything. Heat stayed low where it belongs. Then a few hours later the overheat symbol.
      08-23-2016, 12:04 PM   #10
ATH_M2
Drives: LBB M2
Does it look like coolant came out from the expansion tank cap? If it didn't then maybe you might have an electrical glitch/error vs actually overheating. When the water pump fails or car decides it wants to overheat coolant will blow out of the expansion tank cap. I would get it scanned to see the codes.
      08-23-2016, 07:08 PM   #11
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Turns out the expansion tank has a crack along one of the seems. Waiting to hear about the boost issue still.
e90post
