Can someone please help me, I might have the strangest N54 issue
08-18-2016, 11:24 AM | #1 |
Rep 2,189
I have what I call a "bump" or a "thump" when going WOT and RPMs climb.
My logs look near PERFECT. The only thing that is even a clue in the logs is the rpms DROP ever so slightly while this "bump" happens. Look at the log around 4k rpms in this log and you'll see it happening. Does anything else in the log stand out? I've changed plugs and the issue persisted. I ditched stock DVs to a Tial BOV and still the same. I've tried various MHD tunes, still exists. Seems to be only under high load/lows rpms, as soon as rpms get over 4k or so it never happens. At my wits end, car runs perfect otherwise, no misfires or codes. Can someone please help? Log: http://www.datazap.me/u/miller335/71...og=0&data=4-22
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
08-18-2016, 01:16 PM | #3 |
Rep 2,189
All traction aids off and road is 100% smooth.
08-18-2016, 01:34 PM | #6 |
Rep 2,189
08-18-2016, 01:37 PM | #7 |
Rep 2,189
I'm going to clean vanos solenoids when I change my oil in a few weeks also.
Probably wouldn't hurt to change coils but no misfires or nothing. I hate just throwing parts at the car blindly though.
08-18-2016, 02:14 PM | #8 |
Roll Tide
591
Rep 2,345
Solution: downshift.
Cost: $0.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306 |
08-18-2016, 03:05 PM | #10 | |
Rep 2,189
What do you think would cause this?
08-18-2016, 03:14 PM | #11 |
Rep 1,497
08-18-2016, 03:18 PM | #12 |
Guest
Rep n/a
Drives:
There's definitely something wonky going on in between 4021 and 4215 rpm, not related to throttle closure. AFR between the two banks goes wacky, then recovers.
I've heard of new primary O2 sensors fixing similar issues during low load situations, but not sure if a new set will help you here. Interested in hearing what the more knowledgeable members have to say though |
08-18-2016, 04:18 PM | #13 |
Rep 2,875
Have you switched back to stock tune? Try that and see if it still happens.....
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
08-18-2016, 05:27 PM | #14 | |
Rep 2,189
Only when I run an E85 does it seem to happen.
08-18-2016, 06:38 PM | #15 |
Rep 615
I had a hiccup and it was a leaking injector.. Ran lean then dumped rich , felt like a mis ...
///Mposter208.00 |
08-18-2016, 08:48 PM | #16 |
Rep 2,189
That's exactly how describe, like a miss./hiccup.
08-18-2016, 09:20 PM | #17 | |
Rep 1,340
08-19-2016, 09:01 AM | #18 |
Rep 2,189
08-19-2016, 10:10 AM | #19 | |
Rep 2,189
Or just this WOT issue Im also having?
08-25-2016, 02:31 PM | #20 |
Rep 2,189
Any other causes for this other than injectors?
Doesn't seem to have this issue on pump gas. I don't want to spend over $1k on injectors for it to be a maybe fix.
8Series12.50 |
08-25-2016, 03:36 PM | #21 |
Rep 232
weird. i definitely see the rpm bump and corresponding fluctuations in boost. could be coils or maybe switch out to a different plug.
i do however see that your lpfp is taking a big hit immediately prior, dipping down to about 50psi, but i'm not sure if its related. you mention this "bump" only happens on e85, so it may have something to do with the increased fueling demand. might be time to invest in a new pump. |
08-25-2016, 04:48 PM | #22 | |
Rep 2,189
