are inlets safe?
08-11-2016, 08:02 PM | #1 |
Rep 606
so I see we got a couple horror stories about inlets failing and causing starvation of air to the turbos.
edit- was silicone inlets that failed. they caved in and caused turbo to blow. good thing I bought the metal ones. |
08-11-2016, 08:59 PM | #2 |
Guest
Rep n/a
Drives:
If you actually bothered to read the replies in those threads, you would have noticed that install error was the cause of failure in each occasion.
I guess something as simple as pumping gas could lead to "horror stories" too; just depends on whether or not you're doing it right... |
08-11-2016, 10:42 PM | #4 |
Rep 1,532
I actually am about 80% of the way done with my endurance testing with this. Will make a thread about it in a couple weeks most likely, if not before. Bottom line is that as long as you have a reasonable air filter in place, they shouldn't collapse until you're approaching STUPID power levels. I'm talking 2000+ hp range. Hook them up to your stock airbox with a clogged filter and big turbos... well then you're on your own. I'll go into more details when they're done soaking in a vat of hot used motor oil for the specified length of time and retested.
Chris |
08-12-2016, 01:08 AM | #5 |
Rep 630
Drives: '09 335 E93 6MT
OP, If you read even more, some people are having fitment issues with the Hexon metal inlets. Not sure if they have resolved that. I am glad to see V2 have the PCV heater adapter.
Convertible | Manual | M-Sport | MHD Stage 1 + FMIC | 335is Clutch | ER CP | RB Inlets | VRSF 5" Stepped FMIC | M3 F/R Control Arms | KW V3 | Hawk HPS Pads | Stoptech Slotted Rotors | Blackvue DR650-2CH Dash Cam | LCI Taillights
08-25-2016, 08:24 PM | #6 |
Rep 174
[QUOTE=FCobra94;20399244]If you actually bothered to read the replies in those threads, you would have noticed that install error was the cause of failure in each occasion./QUOTE]
Wait, do you mean read every word in these threads before jumping to a conclusion? That sounds hard, like school. |
