Flashing CEL
08-11-2016, 01:04 PM | #1 |
Rep 137
Flashing CEL
I'm having this weird issue where when I drive the car hard, it'll start flashing the small CEL and then it goes away, then comes back after a few seconds and then goes away but there are no codes.
Car pulls fine, no misfires or rough idle. Anyone? |
08-11-2016, 01:37 PM | #2 |
Rep 2,083
Flashing CEL is typically a misfire. I would scan for codes ASAP.
I have also read that a flashing CEL can indicate that it's a more serious issue that could potentially cause permanent damage if not fixed soon. Since you say it's not misfiring, I would scan for codes before driving it.
2013 135is DCT Carbon Black Metallic |
08-11-2016, 04:43 PM | #6 |
BimmerPost Supporting Vendor
24199
Rep 190,807
If you have a tune, i recommend you take a log
08-11-2016, 07:00 PM | #7 |
3441
Rep 79,211
You need a Bavarian technic tool / BMW Diagnostic tool or other high end (snap on) tool that can read BMW shadow codes.
It's likely a misfire. Generic code readers don't show everything. |
08-11-2016, 07:54 PM | #8 |
Rep 137
The steering doesn't shake and it doesn't go into limp mode. The small CEL just flashes a couple of times, goes away and then will flash again even at idle.
08-12-2016, 02:48 AM | #9 |
Rep 2,841
08-12-2016, 09:48 AM | #11 |
Rep 82
Doesnt a flashing CEL usually indicate that you need to pull over immediately because somethings about to fail catastrophically if you dont?
Edit - OP i dont mean to scare you, i just recall reading in other car manuals that flashing CEL usually means something bad. (i.e Not enough oil in the car) |
