M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > 18" Wheel Options
      08-02-2016, 11:09 AM   #1
F87LUV
F87LUV's Avatar
Drives: '16 M2, '23 GT4
2023 Porsche GT4  [5.00]
2016 BMW M2  [8.66]
I know a few people will be running a winter setup. Can you all post the rims you're going with (if they're 18s")? So far I haven't seen anything I've liked for the car and I don't wanna spend a fortune.
IG: Trackinheels
      08-02-2016, 01:40 PM   #2
Pol
Pol's Avatar
Belgium
1119
Drives: M2 CS BMS DCT August 2020
I ordered the 640M's but will let them repaint in satin black.
      08-02-2016, 01:51 PM   #3
Pol
Pol's Avatar
Belgium
1119
Normally 640M is a set of 2x18x8,5" and 2x18x9". I asked the seller if it might be able to deliver 4x18x9" to mount 245-18 Michelin Alpin all around. Waiting for an answer.
      08-02-2016, 02:24 PM   #4
F87LUV
F87LUV's Avatar
2016 BMW M2  [8.66]
I'm torn between that and getting 19" winters. Really don't want wheels that big though.
IG: Trackinheels
      08-02-2016, 03:10 PM   #5
Pol
Pol's Avatar
Belgium
1119
I prefer 19's too, but for a winterset ... And I hope they will not look as bad as the ones in silver.
      08-03-2016, 11:02 AM   #6
Elwood74
Elwood74's Avatar
Drives: 2017 M2
Curious as well. Definitely do not want 19's for the winter. And if there is a square setup that would be even better.
      08-03-2016, 11:18 AM   #7
F87LUV
F87LUV's Avatar
2016 BMW M2  [8.66]
So far only the 640M wheel and these are the ones I've found to fit.
http://www.tirerack.com/wheels/Wheel...ModClar=&a=FW5
IG: Trackinheels
      08-03-2016, 02:11 PM   #8
koastal
Australia
376
Drives: F87
These Semi forged Koya SF03,s fit
We dont have winter here, so these are for the track
18 x 9 - et: 20
18 x 10 - et 35
      08-08-2016, 08:16 AM   #9
d0scas
Drives: 08' 135i 16' M2
18 x 9 - et: 20
Attachment 1469601
Do you have any more full car shots of it on 18s curious how it looks lowered on the springs on 18s
      08-08-2016, 08:41 AM   #10
Smiley1175
Smiley1175's Avatar
Australia
283
Drives: M2
18 x 9 - et: 20
What do you think of the Ventus TD, and what sizes did you go with?
      08-08-2016, 01:01 PM   #11
quikM2
Drives: 2017 Jahre M3
clearing our M brakes is the challenge. 18's will be limited. square set up is fine for winter but 19's will have all the options. I think an 8 or 8.5 width should be fine though on the 19 inch rim for winter. narrower tires do better performance wise in terms of cutting through snow and stopping distance.
      08-08-2016, 03:33 PM   #12
koastal
Australia
376
Drives: F87
They are the old track tyres of the 135.
265 rear
235 front
The Hankooks work pretty good - maybe in the same category as the A050,s or DZ03. Not really sure as I havent used the yokohamas or the dunlops
      08-14-2016, 09:43 PM   #13
winterrogue_F87
Queen of Motorsports
winterrogue_F87's Avatar
Drives: BMW 2016 M2
2016 BMW M2  [0.00]
2015 BMW 228xi  [0.00]
I'm using the stock rims and buying winter tires.
Instagram @winterrogue_F87
Tai Winter Targaryen
      08-15-2016, 11:24 AM   #14
Ex-MINI
BMW Newb
Ex-MINI's Avatar
Drives: 2016 LBB M2 DCT
I've found a an OEM M3/M4 winterset. I'm pretty sure it will fit (the wheels at least) but wanted to confirm the tires won't be too wide at the front.
Its the staggered 640M set, so 18x8.5 at the front and 18x9 at the rear. Tires are the Conti Winters 255/40/18 all around.
Can someone confirm for whether the fronts will rub or not?
      08-15-2016, 11:28 AM   #15
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
Typically you will have more tire and brand choices with an 18"
      08-15-2016, 11:48 AM   #16
F87LUV
F87LUV's Avatar
2016 BMW M2  [8.66]
Not many that clear the brakes.
IG: Trackinheels
      08-19-2016, 12:06 AM   #17
tke743
tke743's Avatar
Drives: LBB M2 Comp
Check out the group buys for the M3/M4 on the forum. Same brakes so should be fine (I will be checking soon). I got the 18" Apex Wheels and they look great.
Formerly - "That Guy" in the purple BMW
      08-19-2016, 02:13 PM   #18
IS+1
Drives: 2017 M2 (AW 6MT)
My priority for winter wheels is that they are inexpensive without looking too horrible, and I tend to run one size lower than stock, so I too will be looking for 18" wheels.
I have been a loyal Tire Rack customer for almost 20 years, and cannot be bothered to shop elsewhere because I cannot find another place that can match their prices for wheels and their level of service.
I also plan to go AW so will be looking for a darker wheel for aesthetic reasons.
As of now, Tire Rack only has one 18" wheel option listed for the M2, and it comes in black, so if I were to buy a winter wheel right now, this is the one I would buy- the RIAL P10:
http://www.tirerack.com/wheels/resul...6&autoModClar=
Granted it's not the fanciest wheel out there, but during winters here the roads are so riddled with potholes that I'd much rather write off a $200 wheel than $500 one.
Also with the amount of deep snow we get, I will be running a narrower square set-up: 235 or 245 all around. I realize that may sacrifice some dry pavement grip, but in the winter that is the least of my concerns. I absolutely hate our winters
supersam283.00
m2
