07-22-2016, 05:35 PM | #1 |
1765
Rep 7,651
RKP GTS High Wing Mount Set
BMW's M4 GTS includes an aerodynamics package that reduces lift at high speed, and enables more confident driving on the race track. Unfortunately, because BMW has to appease the general buying public, and must comply with rear visibility guidelines, the rear wing on the GTS quite literally falls short of it's potential by being positioned quite closely to the trunk surface. By being positioned only 6.5" away from the trunk surface, the GTS wing is exposed to dirty, turbulent flow which does not enable the airfoil to operate as efficiently as possible. RKP's high mounts for the GTS wing place the wing much higher relative to the M4's roof, exposing the wing to clean, laminar airflow. In doing so, further performance can be extracted from the GTS wing. The RKP mounts are constructed from billet aluminum, and are designed to minimize weight while being a direct fit to the M4 trunk. The mounts are finished in the same grey as the original GTS mounts for a clean look.
07-22-2016, 06:18 PM | #2 |
Rep 1,523
To me the oem mounts looks more stable with its wider and bigger base where it meets the trunk. Also there seems to be a machined groove for a rubber o ring for water proofing.
07-23-2016, 12:34 AM | #3 |
Rep 582
OEM mounts just looks so much better. Bevels are better and top of RPK has some strange way they cut the holes too close to the top. Agree that bottom should look more substantial as well. I would not get these for my GTS when it comes in.
07-23-2016, 09:02 AM | #4 |
BimmerPost Supporting Vendor
2868
Rep 11,374
The RKP mounts are just as stable as the OEM. Not that I recommend it but you could push the car using the mounts alone. The top washers are moved to the inside of the trunk. We have tested the mounts on the iND M4 using all OEM GTS hardware and there is zero water leaks.
07-25-2016, 08:16 AM | #5 |
Rep 629
I'd have to disagree. The rounded edges on the mounting surface really make it look like the wing would easily bend backwards. The oem mounts have much more marerial on the trailing edge. Combine that with less surface area to spread the load out on the trunk lid and no way to seal it up and you have a part that's sub par compared to oem. I think rkp should go back to the drawing board on this one.
AustinY 220834.00 M4_GTS1152.50 |
07-25-2016, 08:58 AM | #6 | |
Rep 231
If you were relying on the trunk lid alone to support the brackets, I could see your concern, but all of the support is handled from inside the trunk. For water sealing, item 10 is swapped to the inside of the trunk also. Hope to have mine all set up within a few weeks and will have some more real world feedback. |
07-25-2016, 09:19 AM | #7 |
Rep 629
Ah ok I see what you're saying. It just seems to me like the high mounts would want to just bend backwards around the rounded edge, especially at a more agressive wing angle. I guess time will tell when people start hitting the track with them. I'd imagine rkp did extensive testing already so hopefully it's not an issue.
07-28-2016, 12:36 AM | #8 |
Rep 3,403
LOL. RKP is just a knockoff shop trying to parade around as a high-end brand.
06-08-2017, 08:53 PM | #9 | |
Rep 4
06-12-2017, 02:17 PM | #13 |
Rep 490
06-12-2017, 04:50 PM | #14 | |
Rep 1,394
06-12-2017, 07:03 PM | #15 | |
Bored at work....
890
Rep 5,391
Did you ever mount these?
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
06-15-2017, 10:22 AM | #17 |
Faster on 2wheels
131
Rep 381
Any risk of the higher wing putting more pressure on the trunk and causing future damage? I assume BMW tested the current setup rigorously before moving to production...
06-15-2017, 10:41 AM | #18 | |
2868
Rep 11,374
Not 100% the same since the M235iR uses a larger thread pattern.
Last edited by Nate@IND; 06-15-2017 at 01:09 PM.. Reason: Added installed photo on GTS |
06-18-2017, 11:30 AM | #19 | ||
Rep 10,825
IND-Distribution9582.50 |
