Smoked tail lights
03-22-2008, 04:54 PM | #1 |
In charge of Evil Empire
20
Rep 313
Drives: 2009 X6 5.0
Garage List 2009 911 Targa 4S [0.00]
2008 335xi cpe [0.00] 2007 530xi [0.00] 2006 Mustang [0.00] 2001 Audi A8 [0.00] 1997 Subaru SVX [0.00] 1985 Mustang [0.00] 1982 Mustang II [0.00] |
Smoked tail lights
Does anyone know if smoked/tint darkened tail lights are legal on Colorado? I have found plenty on window tint laws, but nothing about this..
For now -- Frozen White 2013 BMW M3 and Porsche Cayenne Turbo S Recent - 2009 Porsche 911 Targa 4S; 2009 X6 5.0i; Aston Martin V8V; 2012 BMW 650 Prior --- 2008 E92 335xi|6MT|Dinan ECU|Dinan Free Flow|KW V3 Coilovers|Monoco Blue Metallic|Goldenrod --- Nav/USB/PDC/Sport/Premium/Cold Wthr|Yokohama ADVAN Sport|Raptor plates ---> SOLD |
03-22-2008, 06:07 PM | #3 |
Rep 669
Drives: 2008 BMW E92 335xi
From the Colorado Revised Statutes... the question is whether you can see the lights at the required distance... not whether they are tinted. So tinted will be fine if the visability requirements are met (and likely be fine unless a cop wants to give you a hard time).
You wouldn't really want to impede the light too much anyway... that's the rear end of your baby your talking about! --- 42-4-206. Tail lamps and reflectors. Statute text (1) Every motor vehicle, trailer, semitrailer, and pole trailer and any other vehicle which is being drawn at the end of a train of vehicles shall be equipped with at least one tail lamp mounted on the rear, which, when lighted as required in section 42-4-204, shall emit a red light plainly visible from a distance of five hundred feet to the rear; except that, in the case of a train of vehicles, only the tail lamp on the rear-most vehicle need actually be seen from the distance specified, and except as provided in section 42-4-215.5. Furthermore, every such vehicle registered in this state and manufactured or assembled after January 1, 1958, shall be equipped with at least two tail lamps mounted on the rear, on the same level and as widely spaced laterally as practicable, which, when lighted as required in section 42-4-204, shall comply with the provisions of this section. (2) Every tail lamp upon every vehicle shall be located at a height of not more than seventy-two inches nor less than twenty inches, to be measured as set forth in section 42-4-204 (3). (3) Either a tail lamp or a separate lamp shall be so constructed and placed as to illuminate with a white light the rear registration plate and render it clearly legible from a distance of fifty feet to the rear. Any tail lamp or tail lamps, together with any separate lamp for illuminating the rear registration plate, shall be so wired as to be lighted whenever the head lamps or auxiliary driving lamps are lighted. This subsection (3) shall not apply to neighborhood electric vehicles. (4) Every motor vehicle operated on and after January 1, 1958, upon a highway in the state of Colorado shall carry on the rear, either as part of a tail lamp or separately, one red reflector meeting the requirements of this section; except that vehicles of the type mentioned in section 42-4-207 shall be equipped with reflectors as required in those sections applicable thereto and except as provided in section 42-4-215.5. (5) Every new motor vehicle sold and operated on and after January 1, 1958, upon a highway shall carry on the rear, whether as a part of the tail lamps or separately, two red reflectors; except that every motorcycle and every motor-driven cycle shall carry at least one reflector meeting the requirements of this section, and vehicles of the type mentioned in section 42-4-207 shall be equipped with reflectors as required in those sections applicable thereto. (6) Every reflector shall be mounted on the vehicle at a height of not less than twenty inches nor more than sixty inches, measured as set forth in section 42-4-204 (3) and shall be of such size and characteristics and so mounted as to be visible at night from all distances within three hundred fifty feet to one hundred feet from such vehicle when directly in front of lawful upper beams and head lamps; except that visibility from a greater distance is required by law of reflectors on certain types of vehicles. (7) Any person who violates any provision of this section commits a class B traffic infraction. --- 42-4-215. Signal lamps and devices - additional lighting equipment. Statute text (1) Any motor vehicle may be equipped, and when required under this article shall be equipped, with a stop lamp or lamps on the rear of the vehicle which, except as provided in section 42-4-215.5, shall display a red or amber light, or any shade of color between red and amber, visible from a distance of not less than one hundred feet to the rear in normal sunlight, and which shall be actuated upon application of the service (foot) brake, and which may but need not be incorporated with one or more other rear lamps. Such stop lamp or lamps may also be automatically actuated by a mechanical device when the vehicle is reducing speed or stopping. If two or more stop lamps are installed on any motor vehicle, any device actuating such lamps shall be so designed and installed that all stop lamps are actuated by such device. (2) Any motor vehicle may be equipped, and when required under this article shall be equipped, with lamps showing to the front and rear for the purpose of indicating an intention to turn either to the right or to the left. Such lamps showing to the front shall be located on the same level and as widely spaced laterally as practicable and when in use shall display a white or amber light, or any shade of color between white and amber, visible from a distance of not less than one hundred feet to the front in normal sunlight, and the lamps showing to the rear shall be located at the same level and as widely spaced laterally as practicable and, except as provided in section 42-4-215.5, when in use shall display a red or amber light, or any shade of color between red and amber, visible from a distance of not less than one hundred feet to the rear in normal sunlight. When actuated, such lamps shall indicate the intended direction of turning by flashing the light showing to the front and rear on the side toward which the turn is made. (3) No stop lamp or signal lamp shall project a glaring or dazzling light. (4) Any motor vehicle may be equipped with not more than two side cowl or fender lamps which shall emit an amber or white light without glare. (5) Any motor vehicle may be equipped with not more than one runningboard courtesy lamp on each side thereof, which shall emit a white or amber light without glare. (6) Any motor vehicle may be equipped with not more than two back-up lamps either separately or in combination with other lamps, but no such back-up lamp shall be lighted when the motor vehicle is in forward motion. (7) Any vehicle may be equipped with lamps which may be used for the purpose of warning the operators of other vehicles of the presence of a vehicular traffic hazard requiring the exercise of unusual care in approaching, overtaking, or passing and, when so equipped and when the said vehicle is not in motion or is being operated at a speed of twenty-five miles per hour or less and at no other time, may display such warning in addition to any other warning signals required by this article. The lamps used to display such warning to the front shall be mounted at the same level and as widely spaced laterally as practicable and shall display simultaneously flashing white or amber lights, or any shade of color between white and amber. The lamps used to display such warning to the rear shall be mounted at the same level and as widely spaced laterally as practicable and, except as provided in section 42-4-215.5, shall show simultaneously flashing amber or red lights, or any shade of color between amber and red. These warning lights shall be visible from a distance of not less than five hundred feet under normal atmospheric conditions at night. (8) Any vehicle eighty inches or more in overall width may be equipped with not more than three identification lamps showing to the front which shall emit an amber light without glare and not more than three identification lamps showing to the rear which shall emit a red light without glare. Such lamps shall be mounted horizontally. (9) Any person who violates any provision of this section commits a class B traffic infraction. |
