BMW M3 Forum (E90 E92)
EXXEL Distributions
      07-04-2016, 11:53 PM   #1
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
DIY: DCT Filter Change
I saw some threads about having the DCT fluid changed / topped off, but I have not seen a comprehensive thread about changing the actual filter. Most of the folks who are curious about this have been turned off by the fact that the DCT oil lines runs right across the filter, discouraging owners from performing this DIY.
Well, this was on my list of things to do when my car turned 100K and finally got to it (read: manned up the courage) today on America's Bday.
This DIY is very straight forward, difficulty about a 3/10
ADDITIONAL TOOLS NEEDED:
C-CLIP remover - I just want to point out and say DO NOT SKIMP OUT ON THIS TOOL! SPEND THE $20 BUCKS AND GET A GOOD QUALITY ONE (I bought mine from Sears: Craftsman)
http://www.sears.com/craftsman-profe...p-00947412000P
Torx E10 socket
16MM socket
8in extension
OEM Filter Kit - Includes new circlip, filter cover, and Getrag filter. I bought mine from FCP
https://www.fcpeuro.com/products/bmw...er-28107842840
1) Read up on this DIY to understand the fluid change procedure.
http://www.m3post.com/forums/showthread.php?t=746269
Ensure car is level. I had the rears on ramps and fronts on jack stands.
2) The filter is located on the driver's side and completely visible once you remove the DCT transmission cover.
3) Remove the aluminum skid pan using 16mm sockets on the bolts. You need to take this off so that you can gain clearance to remove the torx bolt.
4) Use the extension to remove the E10 torx. Once this is removed, the aluminum piece holding the two oil lines should slide out fairly easily.
**HAVE A DRIP PAN PLACED UNDER THIS SPOT, SOME FLUID WILL SPILL OUT**
Pull the oil lines out. Access to the filter is now possible
5) Use the circlip tool to take out the one in the transmission. Next, to remove the plastic cover, I used pliers to rotate it to get it loose and pull it out. Some fluid will spill out again, so have the drip pan handy! Once that's out, the filter is right there. To get it out, I used a pick and pulled on it. Comes out very easily, just like removing the engine oil filter from the oil filter cap.
6) Re-install everything in reverse order with new replacement parts. Make sure you feel a small click when reinstalling the filter so that the gasket is seated properly inside. The filter itself will droop slightly but the cover will support it once it's installed. The circular plastic cover pushes into the transmission with some force. To make the circlip installation easier, try to get part of the clip into the groove first and work the rest in with the tool. When reinstalling the oil lines, be careful to not over tighten the Torx bolt!
7) The amount of DCT fluid lost is very minimal, probably like 1/5th of a quart if anything. So if you want to re-fill and check, follow step 1. The only thing I did additional was to leave the engine running once I reached required temperature and completed the 1min 2k RPM hold, undo the filler bolt, and add fluid until it spills out. Hand tighten filler bolt, shut off engine, and finally torque bolt into spec.
8) Clean up areas with brake cleaner and reinstall the skid pan and DCT cover.
FYI, I've attached BMW's SIB and utilized Step #10 to make sure it's properly filled. It may be scary at first with the engine running and you may think DCT fluid will spill out, but not if the DCT is under filled.
File Type: doc SI B28 03 08 M-DCT fluid fill and checking.doc (104.0 KB, 782 views)
M43S7RO503.00
AndyW667.50
alpnwss31.50
      07-11-2016, 09:14 PM   #2
MTM
Drives: 2009 M3
Looks fantastic. Thanks for sharing. Am at 76k now...am planning to change this when I hit 100k (or 10 years).
      07-12-2016, 02:36 AM   #3
roastbeef
roastbeef's Avatar
Drives: E92 M3
how did the used filter look when you took it out? any gunk or metal shavings?
Instagram; @roastbeefmike
      07-12-2016, 06:58 AM   #4
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
Or you could do this now and change it again at the next 75k
Looks like a very dark shade of gray. Didn't see any metal shavings though. I was going to take a pic of it but threw it out instead.
      07-12-2016, 07:42 PM   #5
roastbeef
roastbeef's Avatar
Drives: E92 M3
i wonder if its residue from wearing clutches? it would make sense that it would be a fine powder.
      07-12-2016, 07:58 PM   #6
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
It's probably the same stuff that would be on those magnets stuck to the transmission oil pan. Just for curiosity when I took it out, I sprayed it with brake fluid and it washed away very easily
      07-12-2016, 10:04 PM   #7
Groundpilot
Groundpilot's Avatar
Drives: 135I DCT , e92 M3 DCT, Audi A6
So you just changed the filter? Left old DCT fluid in?
      07-12-2016, 10:23 PM   #8
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
Well, depending on the condition of the fluid, you can leave it in if you want since the amount lost to the filter change is minimal. Mine looked pretty good, not that far off in color with the brand new pentosins
I changed mine out though anyway since that was my intention all along
      07-12-2016, 11:55 PM   #9
nholmes
Track Whore
nholmes's Avatar
Drives: women wild
Mine with 103,000 miles:
Blackstone DCT fluid analysis:
Originally Posted by ridinwide View Post
Even though you answered my PM like you're missing a chromosome or have some other issues I still want these.
AndyW667.50
      07-13-2016, 12:15 AM   #10
roastbeef
roastbeef's Avatar
Drives: E92 M3
What's a good interval for this?
I had the dct leak fixed under warranty, but I'm not sure if that means all new fluid...
      07-13-2016, 01:47 AM   #11
nholmes
Track Whore
nholmes's Avatar
Drives: women wild
No idea. I wanted everything fresh for track abuse.
I've seen 75k floating around though.
      07-13-2016, 07:49 AM   #12
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
Yup, mine looked exactly like that. Wasn't that bad of a DIY right?
      07-13-2016, 09:14 AM   #13
nholmes
Track Whore
nholmes's Avatar
Drives: women wild
Nope, not bad at all. Messy though.
      07-13-2016, 09:58 AM   #14
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
Sounds about right
      11-17-2016, 02:00 PM   #15
Patrón
PAZUZU
Patrón's Avatar
Drives: '15 M4
2015 BMW M4  [0.00]
2009 BMW M3  [10.00]
can someone tell me the amount of fluid to purchase?
2009 M3 DCT ESS625+ SOLD
2015 M4 BSM/Silverstone F4LCON
@texasMclub IG @jagemoets
      11-17-2016, 03:46 PM   #16
nholmes
Track Whore
nholmes's Avatar
Drives: women wild
5 quarts of Pentosin DCTF-1 fluid
      11-30-2016, 10:00 AM   #17
Patrón
PAZUZU
Patrón's Avatar
Drives: '15 M4
2015 BMW M4  [0.00]
2009 BMW M3  [10.00]
Thank you.
nholmes542.00
      07-03-2018, 10:41 AM   #18
Honda
Honda's Avatar
289
WingZeroX5 I went through this DIY multiple times, and I still cannot figure out what the clip you bought from sears is used for? Can you point in picture you posted above, what c-clip used for? Can I just use narrow plier to get this DIY done or that tools is a must?
      07-03-2018, 10:56 AM   #19
msan
Drives: 2011 E90 M3 / 2012 X5 35i M Sp
He bought the c-clip pliers from Sears to remove this clip that helps hold the filter in the hole.
      07-03-2018, 11:17 AM   #20
BayE30
Drives: 2011.75 E90 M3 ZCP
is there another way to monitor dct temp for refill purposes without a GT1 setup?
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V]
      07-03-2018, 11:33 AM   #21
msan
Awron guage (which taps into CAN) shows it. So I assume anything that can read/connect to CAN will show transmission temp.
Also it is unclear to me if transmission temp needs to be 40 degrees C to fill or if that is the max it can be? BMW TIS states "Fill until oil emerges - Max. transmission oil temperature 40 °C"
But the SIB states "When it reaches approximately 40° C, open the filler plug again (with the engine running), and top off the fluid level until it starts to overflow."
      07-03-2018, 03:35 PM   #22
Honda
Honda's Avatar
289
Thank you Sir !
m3post
