E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Doing a transmission flush 2 options big price difference? Why? Need advise here.
      05-20-2016, 03:39 AM   #1
mightbaal
g35x
Drives: 2008 BMW 335XI
Ok well as some of you know my transmission is failing so I decided to do a transmission flush just to try it out I have 2 options whats the difference here and are these both approved fluids????
Option 1: $170 shipped
http://www.ebay.com/itm/oem-ZF-Autom...ZU7ui~&vxp=mtr
Option 2: $305 shipped
http://www.ebay.com/itm/BMW-automati...5UxsNQ&vxp=mtr
Like I said this is pretty much a shot in the dark as my transmission shakes bad under power in 2nd gear and shifts to 3rd because it knows there is a problem. One time it slipped completely in 2nd gear and I got the gear light on the dash and was unable to drive the car until it was shut off and turned back on. I figure it would be good to do the flush anyways to get better looking fluid for when its taken in for warranty when it completely fails otherwise the fluid may indicate a clear heavy use of the car and possibly void my warranty?
Thanks for your time.
      05-20-2016, 03:41 AM   #2
mightbaal
g35x
Also what is the Mechtronic Sleeve and what is it for?
^^ Nvm on this looked it up makes me wonder....
      05-20-2016, 04:03 AM   #3
alfazrus
Drives: 2006 e90 330i
Well, option 1 has febi brand fluid vs option 2 is ZF. It's advised to change the mechtronic sealing sleeve (where electrical connector is at back of transmission) while you are in there. Tends to leak, cheap part.
      05-20-2016, 04:20 AM   #4
Supreme214
Supreme214's Avatar
Drives: e90 335i
difference? fluid. first link is febi and second ZF (OE). i've used febi several times and had zero issue. Here is the link if you want to go with febi... plus you'll save some money.
http://www.rmeuropean.com/Products/8...G36-V4176.aspx
change the Mechtronic Sleeve as well since its a common problem for a leak.
Here is the link for the Mech. sleeve
http://www.zftranspart.com/images/custom/mecha.pdf
      05-20-2016, 04:49 AM   #5
mightbaal
g35x
Is that approved fluid for these transmissions warranty companies seem to try anything to get out of a claim....
Also is this all I need for the mechtronic sleeve?
http://www.amazon.com/BMW-Genuine-Se.../dp/B00G09EKV0
I see some with 2 square seals?
      05-20-2016, 06:03 AM   #6
bvanlieu
Drives: Alpine 335d
Why not use a reputable shop like CTS? Their kits include the sleeve and a few extra fasteners if you have any that are corroded etc...OEM ZF fluid.
Plenty of threads here if you search for those who have BTDT using the kits.
- b
      05-20-2016, 06:24 AM   #7
BeastMode335i
Maximus Decimus Meridius
BeastMode335i's Avatar
Drives: F30 335i
If it's failing, and under warranty, why not just have it fixed..??
F30 335i
Melbourne Red Metallic
M-Sport Package
      05-20-2016, 06:25 AM   #8
mightbaal
g35x
Can they argue it wasnt maintained? Car was abused based off fluid? Plus under stock it has bo problems....
      05-20-2016, 06:28 AM   #9
BeastMode335i
Drives: F30 335i
Transmission fluid is supposed to be "lifetime" according to them, so what can they argue..?? I'd be like here, fix it, call me, bye..
F30 335i
M-Sport Package
      05-20-2016, 06:37 AM   #10
mightbaal
g35x
Yea maybe I guess but can they tell the tranmission was under higher than normal strain?
      05-20-2016, 11:12 AM   #11
patents
Drives: 2008 328i
If your mods caused the failure because you sent more power to the transmission that it's supposed to handle, then the warranty for the transmission is void because your mods caused it. It's in the warranty fine print. Actually, it may be in bold print.
Now if you want to want to be dishonest and pretend there were no mods, then that's up to you.
      05-20-2016, 11:20 AM   #12
Antetokounmpo
Antetokounmpo's Avatar
Drives: E90 6MT FBO; '18 F150 Platinum
Every single one of his posts are figuring out how to get the warranty to pay for things that break from being modded..
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      05-20-2016, 11:26 AM   #13
NiNeTyOne
Touring cars rock
Drives: e91 330xi / 997 GT3 Cup
+1 on the Mechtronic Sleeve as you're right there.
LiquiMoly TopTek 1200 meets the factory requirement, and it's awesome fluid. That's what I went to. Bavarian has it in stock for not too much:
http://www.bavauto.com/fland.asp?par...FZRlfgod4G4Ofw
There are two formulations, so call and give them your VIN and they can make sure you get the right one. LM also makes a VERY good 75/140 hypoid that works awesome in our diffs. Since you're right there you may as well.
http://www.bavauto.com/fland.asp?par...FYiVfgodUn4IPg
Mine came out pretty nasty.
Sportwagon Daily: I've done some stuff.
      05-20-2016, 02:14 PM   #14
snayko
Drives: 325i 2006
if you replace solenoids or Mechtronic itself(means take off Mechatronic)
then you need 8 liters of fluid. if it's just fluid/filter and sleeve replacement then you are ok with 6 liters.
      05-20-2016, 06:50 PM   #15
mightbaal
g35x
Does the pan include a new gasket?
      05-23-2016, 04:25 AM   #16
Supreme214
Supreme214's Avatar
Drives: e90 335i
yes its M-1375.4 approved. they are few other brands such as motul, liqui moly and pentosin (all M-1375.4 approved).
yes, thats all you need for the mechatronic sleeve. take your time when doing this....this thing is PITA at least for me .
that square seal is Mechatronic seal adapter which you will have to take the mechatronic unit off.
      05-23-2016, 04:26 AM   #17
Supreme214
Supreme214's Avatar
Drives: e90 335i
yes
      05-23-2016, 05:22 AM   #18
mightbaal
g35x
That a bit of work or na? Like i said my transmission is slipping bad under 20 psi of boost not looking for a miracle but anything is possible? lol
      05-23-2016, 05:22 AM   #19
ozziewizzle
ozziewizzle's Avatar
Drives: 2009 E93.335i.N54 MSport
Just a thought....Vibrations or shaking could also be as a result of failed/ing transmission mounts.:
BMW e93 335i Cabriolet M Sport. Sapphire Black, N54, Michelin Pilot Sport 4s
      05-23-2016, 07:16 PM   #20
mightbaal
g35x
Possible but the car slipped completely out of 2nd the other day and got the gear light on the dash. Clutches are slipping Im thinking not sure on my awtq but the clutches are not handling whatever I am at. Stock boost (map4) is fine tho no slippage firm shifts etc. Gona do the mechtronics sleeve the square adapter and a fluid change and pray because I dont think anything fluid wise will help me here. I am trying to figure out where I can get some heavier duty clutch packs to replace in the transmission.
      05-23-2016, 09:29 PM   #21
Supreme214
Supreme214's Avatar
Drives: e90 335i
no its not hard at all. once you take the pan off its easy.
look at number 6. thats how you take the mechatronic unit off
      05-23-2016, 10:19 PM   #22
mightbaal
g35x
Thank you didnt see the torque specs till now. Problem is my low torque wrench is 5-80 ft lbs my high is 10-150 ft lbs. Might not be that accurate at 8 NM idk. That mechtronics unit that seprate of the valve body or is it the same thing pretty much? Sorry I am an automatic transmission noob. My friend knows alot more about them than me as he is ASE certified.
e90post
