Starter replacement DIY
05-19-2016, 07:09 PM | #1 |
Rep 2,136
Hello guys and gals,
My starter is shot, do you have to remove the intake manifold to do this job? Thanks in advance!
JB4 G5 w/ Backend flash - Walbro 450lpfp - VRSF DPs - VRSF 5" stepped IC - DCI - ER CP w/ Tial BOV - 335is clutch |
05-19-2016, 09:50 PM | #3 |
Rep 67
I just recently did this on my car, i would say be very careful with the breather valve hoses, and no need to completely remove the intake you can move it to the side and use an 11mm box wrench on the back bolt and an extension with the e torx bit on the other bolt. Goodluck
05-19-2016, 10:27 PM | #4 |
Car Enthusiast
895
Rep 1,305
Drives: E92 328i 2007 SC
I did! However, my mechanic where I take things when it's more demanding said he removes some screws/nuts on the intake and a angle it to get access and do the job in 30min without removing it. Wish I knew that when I did it... Especially since I had to do it twice due to a bad new one, before I got a Turner one which as expected was perfect, and Ian overnighted it since I was in a pinch - thanks again!
E92 328i|6MT|ESS SC VT-1 (G.2)|3 stage|22 RPD SC/Meth tune|AA Headers|Snow Performance Meth Injection|Rotiform KPS|R139|PS4S 275.245.19|M3 front|M3 side skirts|MTEC rear|Akrapovic C tips|Koni Sport (Yellow)|Eibach PS|Hotchkis SB|C high-kick spoiler|C mirror Covers|C trim|LCI tails|M3 Control arms|M3 MS|Black E trim|Black kidney's|Full LED Conv|BMW F30 370/345 BBK|ECS SS|ECS Strut Tower Brace|034 Engine-Trans-Rear Mounts
05-20-2016, 09:17 AM | #5 |
Rep 2,136
Thanks for the tips fellas! I'll definitely follow your advice and not completely remove the IM if I don't have to!
05-24-2016, 02:27 PM | #6 |
Rep 2,136
FYI, I replaced the starter this week end in a couple of hours. I didn't have to completely remove the IM along with all the hoses and wires attached beneath it. I just pulled it up and moved it to the side with all the stuff still attached to it and was able to easily access the starter. Not a bad job at all really...
05-24-2016, 09:43 PM | #7 | |
Car Enthusiast
895
Rep 1,305
05-24-2016, 09:58 PM | #8 |
Fuck it dude, let's go bowling.
888
Rep 2,480
I posted up a DIY on this some time ago. http://www.e90post.com/forums/showthread.php?t=1058915
I still don't understand people who do the job with the manifold on. Wish someone would DIY that process.
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
05-24-2016, 10:00 PM | #9 | |
Car Enthusiast
895
Rep 1,305
05-24-2016, 10:05 PM | #10 |
888
Rep 2,480
Only way to rotate it is to remove all but one bolt. At that point, it seems best just to remove it. Then you can inspect all the valves.
