50k Mile Maintenance
05-17-2016, 08:48 PM | #1 |
Rep 39
What do all of you recommend that I do in terms of maintenance at the 50k mile mark? VANOS solenoids? Spark plugs? Any and all suggestions are appreciated. Oil was done 1,000 miles ago as well as air filters. Thanks.
05-17-2016, 09:09 PM | #2 |
Rep 18,737
Change the engine air filter. Maybe clean and swap the VANOS solenoids.
05-17-2016, 09:33 PM | #3 |
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Get it carbon blasted op!
Lol you forgot spark plugs
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
05-17-2016, 09:38 PM | #4 |
Rep 18,737
They are 60,000 mile replacement interval for the 2010 N52. 100,000 miles for the earlier N52 '06 - '09
05-17-2016, 09:51 PM | #5 |
Rep 4,202
Ah! Haha maybe I should look at op's car before saying get it carbon blasted
05-17-2016, 10:33 PM | #6 |
Rep 39
Oh I forgot to mention that I did replaced the engine and cabin air filters 1k miles ago as well as changed the oil. I'm considering the VANOS solenoids but need to do my research on them. Anything in particular that I need to know? I'm riding that they usually don't need to be replaced as much as the seals around the do... Regardless, I'll do anything that is necessary.
05-18-2016, 07:17 PM | #8 |
Rep 51
If you have a 335i, I'd suggest the following-
Oil pan Oil filter housing and gasket Oil change Vanos solenoids Walnut shell blasting If you're running a tune- Injectors Spark plugs Turbos/waste gates (extended warranty to 82k mi) |
05-18-2016, 07:44 PM | #9 | |
Rep 922
OP, maybe change your spark plugs, but it sounds like you're already in good shape. Water pump/thermostat are gonna fail eventually but you probably don't need to worry right now. I would honestly just drive your car and enjoy it |
05-27-2016, 01:28 PM | #10 |
Rep 297
05-27-2016, 09:13 PM | #11 |
Rep 18,737
05-27-2016, 10:32 PM | #12 |
Where'd my VTEC go?
481
Rep 6,067
Keep up with your oil and filter changes and other regular maintenance items. Intake filter could use replacing if it hasn't.
I did tranny and diff fluids at 50k (and 100k) since it's relatively cheap to do and I don't trust BMW's "lifetime fluid" claim. I did spark plugs and serpentine belt/tensioner/pulley at ~100k. All other stuff is replace/fix as needed when broken or acting up IMO.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
05-27-2016, 10:50 PM | #13 |
Rep 484
I like Bavarian Auto's Ultimate Maintenance schedule. Choose the right one for your car. http://blog.bavauto.com/9906/bavaria...nce-schedules/
2007 328xi E92 6MT Jet Black/Coral Red | Tracks: NJMP
05-28-2016, 12:32 PM | #15 |
Rep 134
2008 335xi 6MT Coupe - Monaco Blue on Saddle Brown | fully optioned
05-28-2016, 02:07 PM | #16 |
Rep 18,737
You are correct, I checked the service booklet on line for the 2010 328xi, it is indeed 60,000 miles. They also took the notification out of the CBS as well. Interesting...
05-29-2016, 12:58 AM | #17 |
Rep 5,002
Don't change anything unless it's broke. Replace all filters and do the plugs. I'd recommend trans fluid if it was a car operates in the city or for short trips.
Otherwise, should be solid. |
05-29-2016, 08:42 AM | #18 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
2) flush/ change the power steering fluid 3) spark plugs 4) check brake pads 5) check belts 6) check coolant 7) run techtron 20 gallon formula (you should do this every 6 months to be honest) 8) 4-wheel alignment 9) New air filter or re-charge your oiled filter 10) walnut blasting every 35k 11) Differential fluid - flush? (if you are a spirited driver or you track the car) 12) Change cabin air filter? (should be changed every 36k) 13) START LOOKING FOR DEALS ON A WATER PUMP AND THERMASTAT. IF YOU FIND A DEAL OF 20% OFF OR MORE, PULL THE TRIGGER. Better that it sits on your shelf than the vendor's, if the price is right. From 75k and beyond, your on borrowed time, especially after 100k this is very true. Also, bookmark DIY's on how to change it, and procure the various tools you don't have, in order to make it easier. Last edited by mweisdorfer; 05-29-2016 at 08:55 AM.. |
05-30-2016, 12:57 AM | #19 |
EXPAT
65
Rep 889
Vanos solenoid cleaning will take you 20 minutes max. I did it for the first time on Friday. Take out the bolt, pull them out, and blast with brake cleaner. Shake dry. Coat with a bit of oil and then stick them back in. Would not hurt to replace the seals but not necessary (mine are fine at 111K miles). By the way, my solenoids were clean -- they were spotless as soon as I washed off the oil.
It would not hurt to do the plugs My dealer replaced mine at 50K miles and I did them again (myself) at 111K (they were toast). I think they fall out of spec (the gap) long before 50K miles. If you have never done this before, will take about an hour. Suggest watching a youtube video or two before you attempt this. I would also recommend transmission fluid change. I do my MT every 30K. If I had an auto, I would probably do it every 50K. While you are at it, perhaps the diff fluid as well? Have never done mine before but am thinking about it. |
