CA Door Handle
05-16-2016, 08:09 PM | #1 |
Rep 277
Drives: 08 e92 335i
CA Door Handle
I went to get my key coded so my comfort access will work and I was told that I have to get a new driver side door handle for it to function for that door. I didn't get a price for the job because I moved but I wasn't planning on going to the dealer anyways. Is this something I can diy or go to a Indy for. I can't find much information on this for our cars.
05-16-2016, 08:43 PM | #2 |
Where'd my VTEC go?
481
Rep 6,067
Does the car have the Comfort Access option?
If not, its a lot more complicated than just swapping out the door handle. Only a handful of people have successfully retrofitted it I believe.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
05-16-2016, 09:04 PM | #3 |
Rep 134
Is it a good DIY project?
If your car has Comfort access and your door handle is broken: Yes If your car does not have CA and you want to retrofit it onto your car: ... I'd say no, unless you're really motivated... http://www.e90post.com/forums/showthread.php?t=1211167 |
05-16-2016, 10:00 PM | #4 |
Rep 277
Drives: 08 e92 335i
Yeah my car came from factory with comfort access
05-16-2016, 10:02 PM | #5 |
Where'd my VTEC go?
481
Rep 6,067
Unless the door handle is malfunctioning, you don't need a new door handle. You just need a CA key and the dealer to program the CAS to accept that key for CA functions.
05-16-2016, 10:03 PM | #6 | |
Rep 277
Drives: 08 e92 335i
05-16-2016, 10:09 PM | #7 |
Rep 277
Drives: 08 e92 335i
Is there a DIY guide for performing this? And what are the part numbers I need ? Also where is the best place to buy a handle. I'm guessing Tischer?
05-16-2016, 10:18 PM | #8 |
Rep 14,829
05-17-2016, 12:41 AM | #9 | |
Where'd my VTEC go?
481
Rep 6,067
You can buy a new one from any BMW parts website or try to find a used one (has to be the same color). Just find the part number and google it, then see who's the cheapest.
05-17-2016, 04:34 AM | #10 | ||
Rep 277
Drives: 08 e92 335i
05-17-2016, 04:38 AM | #11 |
Rep 277
Drives: 08 e92 335i
I have the part number but it doesn't yield any results on the Tischer website. 51217199835 And will I have to code it
05-17-2016, 06:33 AM | #12 |
Rep 2,835
Are you sure that is the correct part number? Because when I look it up on realoem, it is listed for European models except for maybe 1 or 2 US entries.
05-17-2016, 07:49 AM | #13 | |
Rep 277
Drives: 08 e92 335i
05-17-2016, 07:52 AM | #14 |
Rep 277
Drives: 08 e92 335i
Anyone know if m3 door handles will fit on our cars. I would assume that they do unless there's some special m technology That makes their door handles more aerodynamic than a normal 3 series
05-17-2016, 08:06 AM | #15 |
Rep 666
CA door handles must be ordered from the dealer. They are pre-painted from the factory per-order with a special paint that allows the touch sensitive functionality to work.
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
05-17-2016, 08:33 AM | #16 | |
Rep 277
Drives: 08 e92 335i
05-17-2016, 08:51 AM | #17 |
Rep 14,829
Did any other car co. use inductive wiring, and does this still exist on new BMWs? It seemed once again to be overengineered......I noticed even Lexus and Infiniti use a button...
05-17-2016, 11:22 PM | #18 |
Rep 277
Drives: 08 e92 335i
Just called Bmw of south Atlanta and was quoted $344 for the driver side door handle... Is this really my only option?
05-18-2016, 02:03 PM | #19 | |
Rep 2,835
Does the sensor on the door pick up the keyfob or is that the CA antennae? |
05-18-2016, 02:05 PM | #20 |
Enthusiast
167
Rep 1,622
What color is your car? I may be able to get my hands on a Jet Black if thats the color you have
05-18-2016, 02:07 PM | #21 |
Rep 14,829
05-18-2016, 08:32 PM | #22 |
Rep 277
Drives: 08 e92 335i
Mine is jet black
