***Logic Motorsports HVI Intake System DIY Thread***
03-14-2008, 06:09 PM | #1 |
Rep 19
Here's a quick DIY guide for those that purchase our HVI intake system.
Tools required: 1. Rachet & 12" socket extension 2. 8mm socket 3. 10mm socket 4. T-15 torx driver 5. Flat head screw driver Stock engine bay: Step 1: Remove the plastic pieces (2) and center piece using 8mm the flat head screw driver. Step 2: Remove the 3 wires from the stock air box and the air tube. Step 3: Remove the front air snorkel with T-15 torx driver and air box clamps with flat head screw driver. Step 4: Remove power steering reservoir bracket with 10mm socket and reinstall it using the relocation bracket. Step 5: Install the intake and filter. Tighten down the clamps and reconnect the wires to the bracket. Reinstall the air snorkel, the 2 plastic pieces and center piece. YOU'RE DONE! |
03-14-2008, 08:44 PM | #3 |
Rep 426
Hi George,
Remove the 3 wires and leave them there till you install the HVI and clamp everything down... Remove the ps bracket and reinstall with the relocation bracket and the provided black oxide bolts and lock nuts. Let me know if you have any other questions. It is very simple once you do it yourself. Have a great weekend guys!! BTW All tracking numbers for yesterdays shipment have been sent!! Best Regards, Max-
Stock Mercedes Benz E55 AMG. 11.96@118.3mph
03-14-2008, 09:15 PM | #4 |
441
Rep 18,331
The wires are connected to the OEM airbox with rubber grommets...take those off the OEM box....Once you install the intake there are three prongs there for you to connect those rubber grommets back onto the intake to make it look neat...Look at you Logic intake, you will see off to the side a bracket with three tooth like notches, thats where the wires go...just insert the rubber pieces onto it!!The wires are hooked up on the back of the OEM airbox on the right side which is the driver side!
03-14-2008, 09:19 PM | #5 |
441
Rep 18,331
When you de-tach the air-tube just leave it detached...the Logic intake is going underneath that airtube...Reason to take it out is so the intake can go underneath it...Once everything is installed, then simply plug the tube back into its original position....
03-14-2008, 09:28 PM | #6 | |
Rep 426
03-14-2008, 09:32 PM | #7 |
441
Rep 18,331
No the airtube is the little plastic hose that u disconnected from the front of the airbox....its not the pipes that u loosen up the clamps on...two totally different things....Just look at the pictures posted above and print it out onto paper and bring it with u into the garage!!! Its really simple...Just print the pics!!!
03-14-2008, 09:36 PM | #8 | |
441
Rep 18,331
03-14-2008, 09:43 PM | #9 |
441
Rep 18,331
To take off that tube, just press the two side together that have ridges on them and pull straight up, but dont' pull it too hard just enough force to disconnect it..
03-14-2008, 09:59 PM | #10 |
Rep 426
Glad you figured it out George!! It is very self explanatory once you are installing the intake. The tube that leads from the brake booster plugs right back on. See the last image.
Best Regards, Max-
03-15-2008, 08:33 PM | #11 |
Rep 136
So simple a caveman can do it...
03-16-2008, 04:32 PM | #14 |
Rep 168
Fit my e90 just fine! Thanks Max! I can definitely feel the car pull a tad harder up top. Finally, I can hear the little snails working. Happy!!
03-16-2008, 05:05 PM | #17 |
Warranty Killer
124
Rep 1,015
Do they provide you with the relocation bracket? that looks like the problem, you need to relocate to make more room.
EUROPROJEKTZ Midwest Member
08 335i Jet Black | too much to name.... |
03-16-2008, 05:13 PM | #18 | |
Rep 168
Push the blow off pipe toward the motor to get more room for the filter. I had to do the same thing. It's a tight fit but works fine.
03-16-2008, 05:14 PM | #19 |
Warranty Killer
124
Rep 1,015
Can you take another picture with a zoom out view of the relocation?
03-16-2008, 05:19 PM | #20 |
Rep 168
Did you do this?
