Tracking down a vibration in the steering wheel
05-16-2016, 12:16 PM | #1 |
Rep 297
Okay, so here's what I've had done so far. Each time the vibration seems to get slightly better but then reappears at a higher speed.
1) Had front brakes replaced (warped rotors) 2) Alignment 3) Rotate and balanced all wheels Yet I'm still getting a slight vibration in the steering wheel around 80mph. 2011 328i 77K miles. Also, recently I had the oil/filter changed, spark plugs changed, replaced OFHG, VCG & OPG. I'm at a loss, need suggestions/opinions. P.S. All work has been performed by the dealer (I have an extended warranty). Last edited by cybermgm23; 05-16-2016 at 12:39 PM.. |
05-16-2016, 04:13 PM | #2 |
Combined Applications Group
1059
Rep 680
When you balance your wheels, try to get them road force blanaced instead of the traditional spinning thing balancer, this can take car of some weird vibrations that cant be solved with the traditional wheel balancer even when it reports the wheel as balanced.
Once this is done, make sure that the mating face of the whee where if sits on the rotor is clean and free of dirt or rust or anything. Even a small sand peble crushed on the edge of the mating area can offset the wheel sitting flush and true vs the rotor and will cause vibrations at some speeds. If all the above is checked and not a possible problem then look into worn bushings. Start with the front wishbones, the are of flimsy design and prone to failure. Good luck |
05-16-2016, 06:59 PM | #5 |
Rep 297
Thanks for your replies. I need to add a small caveat...the vibration seems to be intermittent. I took the car back out today and noticed that it only seems to happen on certain types of road surfaces vs. others. Could it simply be that I'm not used to runflat tires? I've only had the car for 1 month and I've heard that they can be fickle.
05-17-2016, 12:05 PM | #8 |
Rep 297
05-17-2016, 01:51 PM | #10 |
Rep 1,744
Thrust arms, control arms, bent wheels, road force balance, and also wheel bearings. Those would be the next few things I'd look at. I'm changing my thrust arms Saturday. I've done everything else at this point. I got it done to a very small minimum lol.
05-17-2016, 02:00 PM | #11 | |
Rep 358
I would not start swapping out bushings and control arms until you are 100% certain your wheels are straight, true, and properly balanced. If you go back to your tire shop and tell them there's still a vibration they should be more than happy to toss them on the balancer for you. That would be the time to ask about a road force balance. |
05-17-2016, 08:22 PM | #12 | |
Rep 297
Thanks for the advice, I think I'll take it back down to the dealership next week. |
05-17-2016, 08:35 PM | #13 |
Rep 631
is your car lowered? Ive had my tires balanced by multiple shops, the results always ended with vibrations throughout my car. After multiple disappointments I finally took my car to a place which specializes in racing/track vehicles. The guys there knew what they were doing and since my car is lowered with H&R Sport springs they balanced the tires with the appropriate specs. The results are night and day, thanks to them my car drives beautifully now.
I suggest a shop that specializes in special vehicles, as the general tire shop as well as dealerships tend to have inexperienced mechanics as well as only have by the book knowledge. |
05-18-2016, 10:54 AM | #14 | |
Rep 297
Thanks for the tip. No my car isn't lowered, but this vibration at highway speeds is really annoying. And frustrating. |
