E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Bmw E90 On Rough Uneven Roads
      05-12-2016, 12:46 PM   #1
e90ext
e90ext's Avatar
9
Drives: 2008 320i
Anyone with same problem with me.
Have a 2008 bmw e90 with 50.000km on the dash. Our roads are pretty bad, patched everywr and uneven. it feels like a nightmare driving through them. i thought it was me suspension and so i changed it but nothing has changed. is it because bmw e90s have stiff suspension and are low or its something else
Help anyone
      05-12-2016, 02:17 PM   #2
fravel
fravel's Avatar
Drives: Monaco Blue '06 330i
Yeah, that's pretty much it. These cars are generally designed for smooth surfaces.
      05-12-2016, 05:41 PM   #3
dannyhavok
Drives: '11 E90 328xi 6MT
If you're still on runflat tires, get rid of those.
      05-12-2016, 08:52 PM   #4
Needbmwpartzz
Needbmwpartzz's Avatar
851
Drives: 2009 bmw 328i x-drive
Sport sedan is not so great at bumpy roads.
      05-12-2016, 08:57 PM   #5
raleighBahn
Drives: 2009 BMW 328i
All of the above. Sports suspension (if you have, don't change) + run flat (if you have, do change). The tires are awful - get some michelin pilot sport or something.
      05-12-2016, 09:09 PM   #6
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
Even without sport suspension, the E90 is still relatively stiffly sprung compared to other cars. You can get non-runflat tires to soften the ride a bit, or downsize your wheel and tire combo (18 to 17 or even down to 16), and that's about all you can do.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      05-12-2016, 10:29 PM   #7
e90ext
e90ext's Avatar
9
Drives: 2008 320i
thought it was only my car. have a bit of piece of mind, will definitely have to go to the dealer and change my tires.
      05-12-2016, 11:12 PM   #8
kkasson
Drives: 07 BMW 328i, 08 BMW 528i
+1. I have non-runflats and I still felt that might was a little rough...it's nice to see everyone agree that it's normal.
      05-12-2016, 11:52 PM   #9
DOCTOR.Y
Eric_Y
Australia
103
Drives: 2016 340i, 2010 E92 M3
2016 bmw m3 f80  [0.00]
2010 M3 E92  [0.00]
E9X`s suspension is very stiff, on rough road under a certain speed, vibrations from steering wheel, central console, door trim and seat hence noise comes from everywhere. The road doesn`t need to be bumpy, a rough bitumen surface would let us surfer enough.
Non-M sports suspension can give less vibration. Tyre size also helps. 17>18>19 in terms of comfortability, under same suspension. Run-flat tyres also play a role, but I won`t bother to change, mine is S001 which is a lot better than my old RE050 IMO.
In the end, I have to admit I am addictive to this feeling
      05-13-2016, 04:10 AM   #10
e90ext
e90ext's Avatar
9
Drives: 2008 320i
I Agree. even a rough tarred surface would do the trick. Do the F series have the same problems or this a BMW problem across the board
      05-13-2016, 09:56 AM   #11
fravel
fravel's Avatar
It's not really a problem so much as it is a design philosophy. Traditionally, BMW has made the 3-series more oriented towards performance as opposed to comfort. The assumption that is made with this design philosophy is that the car will typically be driven on smooth surfaces. Since you aren't using the car on smooth surfaces, you are seeing the downside to this design philosophy.
If you want a smooth, boat-like ride then get something that is designed more towards comfort rather than performance like Lexus or Acura.
      05-13-2016, 10:17 AM   #12
DOCTOR.Y
Eric_Y
Australia
103
2010 M3 E92  [0.00]
F has a softer suspension compared to its E counterpart hence produces a more comfortable journey. I got F as loan car when my E is in service, different feelings. Overall E is more joyable, F tends to be more practical.
      05-14-2016, 09:33 PM   #13
Wires
Drives: 2016 340i xDrive
I find it becomes even more noticeable when the tires wear out (run-flats). Gets a little spooky when it starts to wander on uneven road surfaces and bad asphalt patch jobs....
e90post
