Another oil question thread
05-06-2016, 12:10 PM | #1 |
Rep 1,782
Can I use this oil in the summer? Performance impacts? Ex. Fuel economy
https://www.ecstuning.com/BMW-E90-32...Moly/ES258726/
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
05-06-2016, 12:14 PM | #2 |
Rep 2,835
According to that jug, it meets BMW-Longlife98...
According to BMW.... BMW Longlife-98 (BMW LL-98)Special long-life engine oil, approved by BMW. Also meets ACEA A3/B3, API SJ/CD, EC SAE 5W-40. Usually required for BMWs manufactured before MY 2002. Obsolete since 2009. |
05-06-2016, 01:18 PM | #3 |
Rep 1,225
Use whatever you want as long as it has the following on the bottle:
BMW Longlife-01 (BMW LL-01) BMW Longlife-01 FE (BMW LL-01 FE)
2010 BMW 335i: Monaco blue metallic/Premium+Sport Auto-Steptronic, BMW PE, Cobb Stage 2
2005 Mustang GT: Redfire metallic/5-spd/Ford Racing (Axle backs, silver Bullitt wheels)/K&N CAI/ Diablo Sport Predator Tuner 1997 Toyota Corolla 1983 Mercedes Benz 380SL Roadster |
05-06-2016, 01:24 PM | #4 | |
Rep 1,782
05-06-2016, 02:48 PM | #5 | ||
Rep 157
Drives: 2011 E90 6MT 335i
"Approved oils can be identified by the following specification: Preferred: LL01 or LL01 FE Alternatively: LL98" Whatever that means I'm not sure. Doesn't elaborate any further than that other than it saying you can use up to 1 quart of non approved oils with API SM or higher but that's oil with no LL spec. |
05-07-2016, 03:19 AM | #6 |
Where'd my VTEC go?
481
Rep 6,067
What's your reasoning to want to run that oil instead of cheaper and more available LL-01 oils like Castrol Edge 0w40 (<$30 for 5qt at Walmart) or even BMW branded oil?
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
05-07-2016, 10:39 AM | #7 |
Rep 1,782
05-07-2016, 02:00 PM | #8 |
Rep 157
05-07-2016, 07:48 PM | #9 | |
Rep 2,835
05-23-2016, 03:25 PM | #10 |
Rep 1,782
So this is what I noticed so far with oil burn off with 5w-30 weights with my car from worst to best:
-Valvoline full synthetic High milage-the worst needed a quart every few hundred miles -Pennzoil Ultra Hyper-pretty bad right next to the valvoline. -Liqui-Moly-not bad but not the best. Quart every 3-4k miles. -Valvoline SynPower- was one of the best. A Quart every 5-6k miles. Now I'm trying Pennzoil Platinum with natural gas and so far so good. I'm hoping it'll be in the Liqui-Moly, SynPower range but I doubt it. It'll probably be behind Liqui-Moly. Next I'll try Pennzoil Ultra Platinum with natural gas and I'll see how that goes. Again this was only my observation with different 5w-30 weight oils.
