Confirm Halogen Halo Bulb Type - Downgrading to Halogens
05-02-2016, 02:28 PM | #1 |
Rep 91
One my H8 Cree LED Halo lights burnt out. I don't want to spend $$ to replace them with another set of LEDs, so I am downgrading.
I heard white halogen bulbs were OK. Even better if you can code them to take 13.6V instead of the standard 12v to make them brighter. Before I order the halogens, I had some quick questions. - Any fitment issues if I buy a standard set of H8 halogen's from China on a e90 LCI w/Xenons? - Does the bulb need to rated at 35W ? Can it accept higher wattage? - Anyone in the toronto region do some free coding for me? thanks, K |
05-02-2016, 02:30 PM | #2 |
BimmerPost Supporting Vendor
469
Rep 4,938
Are you replacing the Angel eye bulb or some other bulb on the car?
05-02-2016, 02:40 PM | #4 |
469
Rep 4,938
most all H8 bulbs are the same, i haven't heard of any of them not fitting correctly.
You can code the bulb up to 13.8 v however it will introduce more heat into the headlight then it was designed for potentially discoloring the headlight, and shortening the life of the halogen bubs. Do not go above a 35W bulb as that will draw too much power and create way too much heat in the headlight. LED bulbs will give you a much better color and evenness between the inner and outer rings however.
05-02-2016, 02:47 PM | #5 |
Rep 91
Thanks for the info! I definitely agree that LEDs are much better... but I'm no longer too picky about getting perfection, especially on an older vehicle.
05-03-2016, 08:15 AM | #6 |
Rep 2,366
Drives: 2007 E90 323i (Cdn)
If your car can be coded via the wifi obd adaptors and the Carly app, message me and I can help you out.
Just got it so have no experience with it, but supposed to be straight forward.
05-03-2016, 08:41 AM | #7 |
Rep 91
Cool, thanks! It should work. I ordered the halogens. May take a couple of weeks to arrive.
05-04-2016, 07:56 AM | #8 | |
Rep 2,366
