low coolant warning after hitting bumps in road.
04-11-2016, 08:02 PM | #1 |
Rep 254
For the last few months, my coolant warning will come on when I hit a bump in the road hard. Pothole, uneven road, you name it. I thought at first it was a leak, but I could drive for a hundred miles without seeing a warning, then hit a small hole in the road, and bam...instant warning. If I turn the car off and back on, it's great again until the next hole. FWIW, it seems to be larger holes/bumps, small ones won't do it.
I've checked the expansion tank every time, it's fairly full/not low, so I don't think I have a leak, the only thing I could think of, is that maybe the sensor is going out, but then I can't explain why it only happens when i hit potholes/bumps. Any ideas? Google isn't helping me here
'07 SGM + DG 335i sedan|Navi|ZPP|Rear PDC|Euphoria 6k LED interior|Matte Black Grills|OEM Blacklines|MTEC A.E's|CF Roundels|Alufelgen 19" CS7 with 15/12mm spacers
If I buy something from you please leave me feedback My Portfolio |
04-11-2016, 08:18 PM | #2 |
bOrN To DiE
413
Rep 1,738
Nothing to do with this post but you have pic of your wheel set up with 15/12 spacers. I have the same wheels just wanna see how it looks like your offset is 35F 35R?
04-11-2016, 09:25 PM | #5 |
Rep 290
My coolant expansion tank had a hairline crack. Barely leaked and then started leaking to the point I got the light just two days after topping the fluid off and also saw coolant on my garage floor at work. Dealer replaced under CPO warranty. This was just a few months ago.
2011 BMW 335i XDrive Msport (auto)
04-11-2016, 10:16 PM | #6 |
Rep 589
I agree, sounds like a loose connection. The sensor is in a dry part of the tank, you can just unplug it and twist it out. Take it out and check the connectors. I don't remember where the wires on the connector go but you might also try to follow them back a bit and see if you find anything loosen.
