Loose pulley
04-07-2016, 09:59 PM | #3 |
Rep 766
Find an Indy so you will Atleast get 1/3 of that price down.Do not go to the stealership by any means unless to get your own parts. Grade A Indys save you , your car,& your wallet.
04-08-2016, 05:01 AM | #4 |
Rep 18,734
So not sure what you mean by a "loose pulley", but it is a separate part and can be replaced with out replacing the pump. The part is about $45.
04-08-2016, 12:14 PM | #5 |
Rep 335
you can replace just the pulley. I had to replace mine after it was cracked due to contact with subframe.
OEM part is ~$40 bucks: https://www.ecstuning.com/BMW-E90-33..._3.0L/ES55392/ |
