stickiest setup on 193m !?
04-07-2016, 09:19 AM | #1 |
Rep 1,700
hey guys i have a set of 193m wheels which are 8 in front and and 8.5 in the back whats the widest tires combo could i fit in front and back and is it possible to run a near square fitment or i would have to buy a another set of rims ? whats the most agressive setup can i run with these rims on stock x drive suspension im tired of the oem 225 in front and 255 in the back its not grippy as much as i expected btw i have a 2011 335 e90 x drive thx
04-07-2016, 09:29 AM | #2 |
Rep 1,750
Pilot Super Sports on 335/25R20
2023 G87 M2 - Toronto Red | 6MT | M HAS | CF Roof | BMW 826M Forged Wheels | Mishimoto Skid Plate | Active Autowerks Single Midpipe
Retired: 2022 M240i xDrive | 2021 Audi RS5 | 2019 Camaro 2SS 1LE 6MT | 2016 428i GC | 2011 BMW 335is |
04-07-2016, 10:38 AM | #3 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
225/255 is really the widest you can go with those wheels. Technically, a 245 will fit on the 8'' but you'd then need a 275 for the rear and that is much too wide for a 8.5'' wide wheel. Just get some sticky tires. Brigestone RE11.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
04-07-2016, 10:59 AM | #4 |
Rep 1,700
ah ok that sucks thx for the info buddy !
04-07-2016, 01:20 PM | #5 |
Rep 780
Dont bother, 255/225 is the widest you can go. Period. If you dont mind a sloppy steering feel then go slightly wider and have tons of sidewall flex. I would suggest getting a set of rear wheels and putting them on the front. Run non runflat summer tires 255 on all four.
04-07-2016, 05:45 PM | #9 |
Rep 3,475
I'd wouldn't DD them. RE11 are a much better DD.
04-07-2016, 05:46 PM | #10 |
Rep 1,700
04-07-2016, 05:55 PM | #11 |
Rep 3,475
They'll last 1-1.5 summers and are noisy as hell. RE11 is a much friendlier tire.
04-07-2016, 06:03 PM | #12 |
Rep 2,189
I run 265 PSS's in the rear with 10mm spacer and it will slightly rub over big high speed dips in the freeway.
With no spacers they didn't rub at all.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
04-07-2016, 06:15 PM | #13 |
Rep 3,475
You can easily run bigger than 255 in the rear. Problem is, with his wheels he can't run any wider because xi needs with 1% diameters (larger in front) and 265 is definitely too wide for an 8.5 and 255 is much too wide for an 8''.
04-07-2016, 06:21 PM | #14 |
Rep 113
This will be my second summer on my re71s, hoping that they will last to the end of the year. They are a relatively loud tire but as with most other things you get used to it (just added solid subframe mounts and diff mounts, so tire noise is the least of my concern). If you want a daily tire get pss.
04-07-2016, 06:22 PM | #15 |
Rep 1,700
The pss are noisy as hell ? Whats the difference between re 11 and pss i mean you chose these over the pss ?
04-07-2016, 06:23 PM | #16 |
Rep 3,475
RE71r are noisy as hell. PSS are super quiet. RE11 is a bit louder but offer significantly more grip than a PSS. Of course sacrificing tire life.
04-07-2016, 06:30 PM | #17 | |
Rep 2,189
Didn't pick up on that.
04-07-2016, 06:34 PM | #18 |
Rep 1,700
04-08-2016, 06:03 PM | #22 | |
Rep 1,428
