Wg rattle only on take off (new turbos)
04-07-2016, 07:42 AM | #1 |
Rep 47
Hey everyone, so I got my turbos replaced with brand new Vargas turbos, I have no acceleration rattle and no decel rattle and or revving rattle, but I seem to have some when taking off in reverse or first gear as I'm blimping the throttle to get going. I took a video inside my car port where I park for the noise to be more audible to hear, it's a bunch of reverse and foward starts to hear. Maybe it's normal, please help me with your thoughts.
04-07-2016, 08:36 AM | #2 |
Rep 342
Did you check them before install? I checked my wastegates over and over before I reinstalled my new snails. I would contact Tony at Vargas, hoepfully its a defect and he can take care of it.
2007 E90 335xi | 400WHP // 430WTQ
04-07-2016, 09:04 AM | #3 | |
Rep 47
Not sure if that's normal noise or not. |
04-07-2016, 09:10 AM | #4 |
Rep 342
My car has always had a good amount of rattle in reverse but it's from my aluminum flywheel. Seems odd that new turbos would have rattle whether its in reverse or not. Shouldn't really matter which was the car is moving. Do you tend to ride the clutch more in reverse?
04-07-2016, 10:28 AM | #5 | |
Rep 47
Not really no, I thought maybe it was my clutch Aswell, but it's not I unplugged the vacuume lines and the noise changed so that tells me it's he wastegates. It's not just reverse its rly only when getting moving when engaging the gear and blimping the throttle, did you listen to the video? What do you make of it |
04-07-2016, 11:08 AM | #6 |
Rep 342
I listened to it but cant tell what I'm hearing. I read multiple posts of people complaining about VTT turbos failing after a few months. Could be a quality control issue, but either way you shouldn't have rattle on a new turbo setup. Something seems fishy if Tony said thats "normal" IMO
04-07-2016, 11:24 AM | #7 | |
Rep 53
04-07-2016, 11:36 AM | #8 |
Rep 342
Exactly why I went with OEM on my replacement over Vargas. I'd rather make decent power and not have them fail after 6 months.
04-07-2016, 12:08 PM | #9 |
Rep 47
My turbos are not failing, maybe I just need to play with my settings, I've had them for 6 months now and they pull hard and don't smoke etc. tony actually helped me out a lot and was very kind and answered a bunch of questions, oem will always come back with a rattle. As to why mine do on take off I'dk maybe I have to adjust my menu 12 a little. Or maybe not even wg rattle of you don't see anything wrong with the video yourself
04-07-2016, 12:09 PM | #10 |
Rep 47
04-07-2016, 12:31 PM | #11 |
Rep 342
Its hard to tell in the video I'm hearing a few different rattles. Also since the early E90's came out BMW has revised the wastegate design so the newer ones are supposed to have fixed the issue. Only time will tell, but I bought OEM Genuine BMW parts. So if they do begin to fail and rattle after a year I will be contacting BMW with a strongly worded letter. But the way I see it, if the stockers lasted to 137k these should be able to hit 150k.
Wait till the motor is cool and reach down the the Bank 2 turbo actuator rod and see if you can feel any play. Aside from that there isn't really a way to troubleshoot the actuators. Maybe a clamp or something came loose? Possibly a dropped bolt/tool laying around somewhere? I had a clamp come off my MK4 GLI and it sounded like my turbine exploded into bits. Hopefully its an easy fix, if not, take it up with Tony and hold your ground. GOOD LUCK!
04-07-2016, 12:45 PM | #12 |
Rep 2,083
I can't hear any wastegate rattling from the video. Doesn't mean it's not rattling though. If you're using JB4 or MHD try adjusting the wastegate settings.
2013 135is DCT Carbon Black Metallic |
04-07-2016, 02:07 PM | #13 | |
Rep 47
04-07-2016, 02:08 PM | #14 |
Rep 47
I've tried menu 10 at 0 and at 5000rpm, maybe it's menu 12 I have to adjust since menu 12 is for on throttle rattle?
04-07-2016, 03:13 PM | #15 |
Rep 342
The GLI was a good starter, but I wanted more power haha. I mean if you can't figure it out and it's not affecting anything, maybe just ignore it. Cars make all kinds of odd noises, you could try to have a local shop diagnose it but that might be pricey and get no where.
04-07-2016, 03:59 PM | #16 | |
Rep 47
04-07-2016, 04:08 PM | #17 | |
Rep 342
04-07-2016, 08:45 PM | #18 | |
Rep 47
http://youtu.be/5MGFXntgWHU |
04-08-2016, 09:12 AM | #19 | |
Rep 342
04-10-2016, 08:44 PM | #20 | |
Rep 47
