03-25-2016, 07:35 AM | #1 |
Rep 235
How do you remove turn signal bulbs?
Bought a pair of LED turn signal bulbs and i'm not sure how to remove the stock bulbs. I see the plastic flap located under the wheel well but how do I remove the actual bulb? Thanks in advance.
03-25-2016, 08:29 AM | #2 |
Rep 386
Quite easy actually. Turn the steering wheel all the way till it stops, go to the side where the tire is facing outwards, locate the little door, press down on the two tabs, it comes right out. Reach in all the way to corner and twist the socket out (no need to disconnect any wire harness, as the connector is within the socket).
Once done turn the wheel again opposite side, and redo steps above. |
MASHCT624.00 |
03-25-2016, 08:43 AM | #3 | |
Rep 235
03-25-2016, 09:41 AM | #5 |
Rep 887
Drives: Enzo F23 228i
03-25-2016, 10:38 AM | #6 |
Rep 8,942
Push in then twist. For new bulbs avoid touching with your bare hands. Oil from your hands, even if clean, can cause a focused hot spot and lead to failure. Or at least so I have been told, never experimented with bare hands to test the theory.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
03-25-2016, 10:47 AM | #7 |
Rep 127
In deed, i meant finding another bulb white instrad of amber to switch it
03-25-2016, 11:15 AM | #8 | |
Rep 8,942
2022 Macan S
03-25-2016, 11:18 AM | #9 |
Rep 235
Thanks for the quick tips everyone. I thought it was easy but they werent budging until I gave them a slight push. I went with the Lumen bulbs from CARID that look white and also flash amber when in use. Expensive for a set of bulbs, about $80, but definitely a quality build.
Heres before and after shots: |
03-25-2016, 11:49 AM | #10 | ||
Rep 627
03-25-2016, 12:08 PM | #11 | |||
Rep 8,942
2022 Macan S
03-25-2016, 08:22 PM | #12 | |
Rep 887
03-27-2016, 12:54 AM | #13 | ||
Rep 8,942
2022 Macan S
03-27-2016, 07:34 PM | #14 |
Rep 2
Hi all, first post here. Just picked up my brand new M235 a few weeks ago. I'm interested in getting the bulbs that look chrome but glow amber. I know we need the 150 degree tab design.
Looking at this URL: https://bimmian.com/Accessories-for-...-Signal-Bulbs/ -- can anyone confirm the "1156 Bulbs With 150 Degree Offset - AKA: PY21W" items would work for me? Thanks! |
03-27-2016, 11:27 PM | #15 |
Rep 2
Nvm, Bimmian got back to me with this link: http://bimmian.com/ED~SBUAAA5AS
03-29-2016, 12:20 PM | #16 | |
Rep 3,842
03-29-2016, 06:25 PM | #17 | |
Rep 1,753
03-30-2016, 09:17 AM | #19 | |
Rep 1,753
http://www.ebay.com/itm/2x-Bau15s-15...VWjzEB&vxp=mtr
03-30-2016, 10:26 AM | #20 |
Rep 8,942
FYI I have been running these for two years now, no problem. From Bimmian:
https://bimmian.com/Accessories-for-...-Signal-Bulbs/ 1156 Bulbs With 150 Degree Offset - AKA: PY21W |
03-30-2016, 03:12 PM | #21 | |
Rep 93
http://www.ebay.com/itm/2x-7507DC-Di...NVfGkA&vxp=mtr |
03-30-2016, 03:38 PM | #22 | ||
Rep 1,753
