2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions 2015 m235i cluster change
      03-24-2016, 05:53 PM   #1
bmwn55tuner
Drives: 135i
I am looking into going from a 2014 to 2015 m235i. I recently noticed that the new car does not have the technology package that my original one has. Is is possible to not only retrofit the nav package, but if anything swap out the basic cluster to the other.
Thank you
      03-31-2016, 07:27 AM   #2
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
It's possible, if you buy a secondhand cluster then is must have a lower Odometer reading than your car has or your car will adjust it's mileage to be the same as the new cluster.
google 6WA retrofit...
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube
      04-03-2016, 09:01 AM   #3
Gabrola
Gabrola's Avatar
191
Drives: 340i
You will need to retrofit the navigation system first because the 6WA cluster needs to be connected to the MOST bus compared to the basic cluster which doesn't. The basic headunit doesn't have MOST connectors but the NBT navigation headunit has the MOST connectors.
So you need to retrofit the NBT headunit. Then buy a virgin/new cluster and connect it the headunit using a new MOST cable.
I suggest buying a virgin cluster instead of a used one with a lower odo because some people have had problems writing their VIN without using an EEPROM programmer.
      04-15-2017, 03:31 AM   #4
Wibbles
Wibbles's Avatar
445
Drives: M3LR
You don't have to add an NBT unit but you will need to add the MOST connections from which ever headunit fitted to the car & then code for 6WA.
      07-05-2017, 12:22 PM   #5
Questofthetune
Questofthetune's Avatar
446
Drives: 13 GT50014 AW M235i(sold)
2014 BMW 235i  [0.00]
dredging this up for a question- how do I figure out if my non-navi with HK has the MOST?
      07-06-2017, 03:06 AM   #6
Gabrola
Gabrola's Avatar
191
Drives: 340i
You will have these if your headunit has a MOST connection. If not it will just be a flat area.
Name:  F30 NBT PINOUT.JPG
This non-nav unit has MOST:
This doesn't:
      07-06-2017, 09:08 AM   #7
Questofthetune
446
Attachment 1652206
Attachment 1652207
This doesn't:
Attachment 1652208
Thanks, this is exactly what I was looking for!
2addicts
