03-03-2016, 10:51 AM | #1 |
Rep 613
Hard brake pedal
All
Over the last few days (mornings and after work), when I've got in the car, the brake pedal is rock solid, i.e. as if I've pumped the pedal with the engine off. I have to then press fairly hard to enable the push start. I've noticed no difference once engine started/driving about. Anyone had anything similar? Cars - 335d, Blue Msport Brakes. Cheers, |
03-03-2016, 11:20 AM | #2 |
Rep 1,201
a vacuum is part of the system and it is assisted by the cylinder when the engine is running but when it is not the air will escape, sometimes more due to atmospheric pressure, the weather and all that jazz. this is perfectly normal for you brake pedal to seem hard to press when sitting overnight. and as you start the car in the morning it feels like it sucks itself to the floor again.
my explanation is probably not the best. if this happens within an hour or 2, or even minutes of the engine being turned off it could potentially be an air leak in the system. but if this is not the case o wouldnt worry atall |
03-03-2016, 11:35 AM | #3 | |
Rep 613
03-03-2016, 12:08 PM | #5 |
Rep 841
Exact same problem, same car.
It's been back twice now and they've said there's. I thing wrong with it and it's normal. Coming from a previous F30 I know full well that it's not 'normal'. If you find a solution/resolution then please let me know via PM.
They see me rollin......
03-03-2016, 01:43 PM | #7 |
Rep 613
Just had a ratch around google and it seems it was a known issues on E60s and E90s, with a fix..
http://www.e90post.com/forums/showthread.php?t=589119 http://5series.net/forums/e60-discus...tarted-110628/ I'll give it a week to see if it changes with the weather, then I'll drop it in. |
03-03-2016, 02:54 PM | #9 |
Rep 1,215
Same here, didn't realise it was being raised as a problem.
03-03-2016, 02:56 PM | #10 |
Rep 7,032
Drives: 335xd Msport +
Must be a 335d thing as mine does the same.
03-03-2016, 04:03 PM | #11 |
Rep 1,216
Yup mine feels hard in the morning too.
Anyway, sort of a hijack - if I jump in the car in the morning, fire it up and try to drive off within say 5-10 secs of startup, I get what can only be described as clutch slip. My drive has bit of an incline exacerbating the problem. Anyone else noticed this?
M3 Azurite Black now instead of the 335d. Roughly the same really.
03-03-2016, 04:10 PM | #12 | |
Rep 1,201
03-03-2016, 04:16 PM | #13 |
Rep 46
Yes same on mine when cold, although it does seem fairly intermittent. Didn't really think anything of it since it feels spot on as soon as car starts. All cars have firm brake with ignition off so is it a problem at all?
2015 335d X Drive M Sport Touring - Birds B3 suspension, 380 PS remap, Alcon Advantage Extreme front brake kit.
03-03-2016, 04:32 PM | #14 | |
Rep 15,858
My E91 used to lose vacuum occasionally, no particular pattern, not a normal overnight loss. A regular vacuum loss is not what I'd call normal. But it doesn't mean the braking is not safe, even if it does drop off over a few hours. If you are testing it, remember each brake pump does use up some vacuum. |
03-03-2016, 04:41 PM | #15 | |
Rep 15,858
03-04-2016, 02:18 AM | #16 | |
Rep 1,216
03-04-2016, 02:33 AM | #17 | |
Recruit
104
Rep 314
Also have a firm pedal when the cars been sat for the day at work, have to give it quite a bit of pressure to push down on it. My car's in the garage on Monday anyway so I'll mention it when I drop it off and see what they say. When parking up the other night I got a drivetrain fault on the idrive just as I switched the ignition off. The next morning when I started the car it felt like it was running on 2 cylinders only, then it cut out twice and had to be restarted as I tried to reverse it off the drive. It cleared up after leaving it idling for a minute after this and hasn't reappeared since but it's booked in for monday anyway, I'm thinking an EGR issue of some sort. |
03-10-2016, 07:42 AM | #18 |
Rep 46
Just thought I'd update this thread...having been in the main dealers this morning I took the opportunity to ask them why so many of us feel hard in the morning
Their reply was this is all related to ambient temperature, how cold the car is mechanically, and the brake servo delay in bringing the vac pressure up to correct level. In other words they advised this is absolutely fine and nothing to worry about, since braking should be spot on almost as soon as the engine fires up.
03-10-2016, 12:50 PM | #19 | |
Rep 841
03-11-2016, 07:28 AM | #21 | |
Rep 15,858
Temperatures could explain the odd vacuum issue, but not a regular vacuum bleed. |
