01-06-2016, 03:46 AM | #1 |
Rep 2,324
Sky multi-room install
Does anyone have sky multi-room? If so, is your sky box installed inside a wardrobe?
I have an install booked for the 16th, but need it put inside a wardrobe, do you think they will do this? It will require the lead to be run through the loft, and drilled down through the ceiling....
E46 Coupe 320d M Sport Gone. E92 320d M Sport Gone. F30 335d M Sport Gone.
01-06-2016, 04:38 AM | #2 |
Rep 6,946
Depends very often on your installer. Sometimes having a bit of prep done for them can make things a lot sweeter as can a £20 note or two.
01-06-2016, 05:18 AM | #3 |
Rep 1,580
They'll want to run the cable along the easiest route. Usually this means clipping externally then drilling through the outside wall at the closest point. I'm not sure they'll go into the loft or under floors.
I had multiroom installed last Autumn. The cable run was easy though. Pity you can't yet get Sky Q. Multiroom boxes will be wireless and thus need no cabling. |
01-06-2016, 05:26 AM | #4 |
Rep 8,081
They won't route internally unless you slip 'em a few quid. If your box is in a wardrobe how are you going to control it?
Ian
01-06-2016, 05:49 AM | #5 |
Recruit
104
Rep 314
or buy a droidbox or similar android TV box ..... cheaper and works wirelessly if you have a good enough internet speed so no install needed. I haven't got one but have seen one in use at a friends recently.
01-06-2016, 06:02 AM | #6 | |
Rep 2,324
I will do some prep myself I think.
01-06-2016, 06:10 AM | #7 |
Rep 766
Offer him something but I am not sure they will help much - worse case just let him set things up and then get a handy man to do the job as you want it. Just out of curiosity, how will you be controlling the box? Harmony Hub?
01-06-2016, 06:13 AM | #8 |
Recruit
104
Rep 314
With the android boxes you can stream SKY through it as well as everything else that is available via the internet.
We'll not go into the legalities of doing that, though as your already paying sky for your install downstairs I don't see anything morally wrong with it. |
01-06-2016, 06:18 AM | #9 | |
Rep 2,324
Tbh I can just run the cable to where I want it after he has done the install....
01-06-2016, 12:35 PM | #10 |
Rep 1,643
From experience Sky engineers are fussy, our dish is up on a bit of a roof and they won't touch it as it isn't a 'standard install'. Easiest thing to do is run the cable yourself before they arrive.
01-06-2016, 12:40 PM | #11 |
Rep 2,192
Get a magic eye remote receiver
M3 CP in THE fastest colour (says so in the title )
01-06-2016, 12:43 PM | #12 | |
Rep 2,192
really glad I did mine and the magic eye remote works great too. Putting it in the wardrobe will recue the noise of the unit when it downloads all the stuff overnight too.
01-06-2016, 02:18 PM | #13 |
456bhp for breakfast
425
Rep 913
Managed to convince the Engineer to run our cable under two floors and through an internal wall by moving everything out of the way and lifting the floorboards. Alternatively just ask them to leave enough cable for you to route it yourself after they leave.
01-06-2016, 04:00 PM | #14 |
Rep 2,246
