12-20-2015, 02:57 PM | #1 |
Village idiot
748
Rep 1,236
Electric garage doors
So, I have decided I am rather peeved off with sweeping leaves and crap out of the garage, and its blooming freezing in there too, so I am guna bite the bullet and get an electric roller garage door.
Through my many hours of research I have narrowed it down to two doors. 1) Hormann Rollmatic 2) Seceuroglide excel So does anyone have any experience of either?? I want warm, secure and trouble free. To be honest I am leaning towards the Hormann as zee germans are very good at designing and imparting good workmanship into their products, however the downside with the Hormann is the wait for it to be built (7-8 weeks opposed to 3-4) and the cost and availability of spare parts. The Seceuroglide has extra security features, yet the Hormann has better safety features. Both cost within about £100 of each other fitted, so I am not sure?? Russian Army |
12-20-2015, 03:44 PM | #2 |
Rep 25,112
I'd love a garage door electrically operated, jealous.
I'm not sure I understand how it negates leaves and crud blowing in though? Imagine your next Beemer/car specd with home link, super sweet!
My car made front page of Bimmerpost
12-20-2015, 03:52 PM | #4 |
Rep 251
I've got the Hormann EPU40 double-skinned roller door.
It consists of four horizontal sections and is powered by their "Promatic" operator. It cost about £1200 and was fitted by one guy in a single day with all the old door gear removed off site. I've had it since April 2013 and the only trouble I've had is that it began to auto-stop half way down then return to the open position. That turned out to be the safety feature that detects an obstruction by increased movement force. It was a simple matter to re-program it by putting it through its learning sequence again. All fine since - highly recommended. PS - the F30 doesn't fit in the garage so it's Lady Dosser who gets to use it. |
12-20-2015, 04:18 PM | #5 |
Rep 649
[QUOTE=Chris10Bimmers;19093236
I'm not sure I understand how it negates leaves and crud blowing in though? [/QUOTE] Chris, with my previous up and over door, the bottom edge wasn't properly sealed to the floor and leaves, pine needles, crud etc. would get blown under it. Also leaves collected at the base and when you lifted the door the draft created sucked the leaves into the garage. My new door is a four piece sectional item that lifts vertically, an added bonus because you can park right up to it without bashing the car when you open the door and it sits on a proper rubber seal at the bottom. Danny, a friend has some Hormann doors and has been very pleased with their faultless performance over about 10 years. I chose a Novoferm door over the Hormann simply because Horman could not make one at 4.25 m width with a wicket door and Novoferm could and did. Cost £2300, motorised, including LED downlighters under the lintel. It's quite a large door! Cheers Q
2018 440i Gran Coupe, MPPSK, Champagne Quartz, Ivory White, Adaptive Susp., Sunroof, Active Security, CA and a few other bits.
12-20-2015, 04:46 PM | #6 |
Rep 926
I use this in my car, it's good in the LCI hidden below the sliding cup holder. Fits in the 12V cigarette lighter although it doesn't use the power it has a button cell inside it. Can also get a 2 button version if you have twin doors.
http://www.ebay.co.uk/itm/Hormann-HS...UAAOxykUZThyVJ |
12-20-2015, 05:19 PM | #7 |
Rep 8,489
I also have an electrically operated Hormann overhead sectional door., double skinned and insulated. Five years in, 100% reliable.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
12-20-2015, 05:30 PM | #8 |
Rep 761
Drives: M235i Coupe
Conventional up and over doors don't seem to have the seal at the bottom and sides as the electrically powered doors do, mine is certainly a good fit and draught free.
12-21-2015, 02:11 AM | #9 |
Village idiot
748
Rep 1,236
Thanks guys, yeah, the normal up and over doors don't seal well at all, always cold in the garage (which is good for the beer though) and draughty.
I was heading towards the Hormann so looks like it will be that one then. If you are pretty handy with a spanner, then a decent electric garage door can be had for easily less than 1k. |
12-21-2015, 02:45 AM | #10 | |
Rep 2,559
The leaves do piss me off mind, would love to get a couple of proper sectional doors one day. |
12-21-2015, 03:50 AM | #11 |
Rep 20,651
I assume all you remote control garage owners are aware, however just in case.
http://samy.pl/opensesame/ http://lifehacker.com/test-if-your-g...ens-1710108565 The key thing is make sure you have a rolling code change. Fixed codes are as mentioned literally 'child's play'. Rolling codes will cost a thief a few pennies... http://thehackernews.com/2015/08/rol...ar-garage.html Hacking Tx/Rx data channels is pretty easy as there is not much encryption and when they do encrypt, the first data block is nearly always the primary key. |
12-21-2015, 09:31 AM | #12 |
Village idiot
748
Rep 1,236
Cheers Brigand. I have not fully read it but I know Hormann uses an encrypted remote.
The car lives outside, so if anyone wants to camp outside just in case I press a button then they are more than welcome. Lol. |
12-22-2015, 04:13 AM | #13 |
Rep 795
We had a Thermogilde electric roller door fitted a couple of years ago and I have to admit I didn't do my research and plumped for using a local company which was recommended.
Thermoglide do not seem to get great reviews albeit in that time our door has been faultless, used several times a day(use it for bringing dog into house after a walk for a clean up) and not a single problem. If I were to order again the German doors seem to get the best reviews and probably where my money would go. |
12-31-2015, 07:55 AM | #14 |
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
For those that have fitted The Hormann sectional doors, what kind of cost are we looking at?
Our garage entrance is a single opening about 5m wide, and I'd be looking to get a remote opener.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
12-31-2015, 01:25 PM | #15 | |
Village idiot
748
Rep 1,236
http://www.garagedoorsonline.co.uk/c...-hormann/35311 |
12-31-2015, 01:27 PM | #16 |
Rep 327
I had a quote for a 4.6m auto large sectional door (not Hormann) £1600 supply only as I will fit it myself , not sure if that's very competitive
12-31-2015, 05:28 PM | #17 |
Rep 8,489
Terry, here are the details of the quote (Sept 2011) for my Hormann sectional garage door :
42mm, double skin, insulated 2.44m wide x 2.32m high Supramatic opener 2 x remote control fobs £2,350 fitted, inc VAT May give you some reference point.
01-01-2016, 06:49 AM | #18 |
Rep 182
I paid £1720 for a fitted 5 metre wide Seceuroglide roller door 18 months ago:
To supply & fit one Seceuroglide insulated aluminium roller garage 1 door, white colour finish, weather seal with safety edge to bottom rail, remote control operation, two hand transmitters, internal operating switch, manual override, courtesy light and Seceuro Connect |
01-01-2016, 07:02 AM | #19 |
Rep 19,982
Cheers guys, that's not too bad actually. Redrow want £900 to add a remote to the existing door, and same again to upgrade from a steel door to GRP, so paying £2000 to change the door completely to a more secure, and better all round one including the motor and remote operation looks like a no brainer to me.
01-01-2016, 05:39 PM | #20 |
Rep 3,815
Have the secureglide excel and very pleased with it
My garages leads to the house so needed something tough and the extra security features on the excel just gave me the peace of mind. espeically the bonded slats and the anti lift system. Something even anglia windows ones didnt have at the time Its pretty quiet in operation and the insulated slats help as well. Only suggestion if its facing south / south west so gets lot of sunlight avoid dark colours. Friend got a black one and his garage became an oven in the summer. Not cheapest but very good I've had mine nearly 8 years it was taken down twice and put back up during extension work. Apart from loosing a keyfob no issues. If you are serious drop me a PM as have a good contact for a fitter in M3 corridor depending on where you are based might be able to get you a good price
F30 335i M Sport - now departed
01-02-2016, 05:03 AM | #21 | |
Rep 19,982
