Catless Downpipes Damaging O2 Sensors?
12-09-2015, 12:49 PM | #1 |
Rep 61
I recently had catless downpipes installed on my car and since then the car has been throwing CEL codes P2097, P2098, P0041, P2C7E, P2C6B, P2C31, P2C6A, P2C7F, and P2C32. After doing research I concluded that it was likely either the the O2 sensors were placed in the wrong downpipes or one of them was damaged on install. I took the car back to the shop I had them installed at and they were all placed in the correct spots. However, they said that one wasn't damaged on install and it was likely damaged as a result of the increased exhaust gas flow from the catless downpipes. I've never heard of something like this happening and was wondering if anyone else had.
2018 AW M3CS
12-09-2015, 01:59 PM | #2 | |
Joint Chiefs of Staff
4920
Rep 115,999
Mike |
12-09-2015, 03:31 PM | #3 | |
Rep 61
2018 AW M3CS
12-09-2015, 03:33 PM | #4 | |
BimmerPost Supporting Vendor
24249
Rep 190,924
12-09-2015, 05:19 PM | #5 | ||
Rep 1,643
2007 E92 335i MT
12-09-2015, 05:31 PM | #6 |
Rep 61
Thanks guys. Sent them an email as well as left a message detailing what I found and what I would like them to do. Hopefully they step forward and do the right thing and fix it or at least give me some kind of a discount but judging by the tone with which they spoke to me earlier i'm not holding out much hope.
2018 AW M3CS
12-09-2015, 06:55 PM | #7 |
Rep 91
Are you running a tune like a jb4, mhd, cobb or other utility which will allow you to auto-suppress codes? Even with new post cat sensors, you will constantly have codes being generated running catless dps. The codes which are reported are odd in that there are both out of range rich and lean codes along with the "mixed or muttled" code.
12-09-2015, 07:25 PM | #8 | |
Rep 61
2018 AW M3CS
12-09-2015, 09:04 PM | #9 |
Rep 337
My Indy must have been daydreaming the entire week that he was dealing with my downpipes and O2 sensors. They're usually great and I've worked with them on 80%+ of my repairs and mods.
One big issue when working on the DPs and sensors is that you have to wait a few hours for the pipes to cool down before any work can be done. So I had to leave the car overnight each time. Firstly, he swapped the precat sensors (mixed the left and right). Went back in the next day and left the car with him. After 2 days of driving, I start seeing funky AFR ratios on my MHD gauges. Then precat codes were thrown. Dropped off the car overnight and had him clean the sensors to see if that would help. No luck, 2 days later I'm still getting the same codes. I probably could have just replaced 1 sensor, but at 70k miles, the 2nd sensor was probably on its last leg. I'm not sure if the Indy caused the damaged or if the sensor was on its way out. However I'm leaning toward the Indy's fault. I foot the bill that time as new Bosch sensors weren't too expensive, but mainly because my Indy gives me priority service and super VIP discounts. If you're planning to mod more and keep this car well-past warranty. I highly recommend building a friendly relationship with 1 or maybe 2 good Indys. Last edited by limitdown; 12-09-2015 at 09:15 PM.. |
12-09-2015, 10:10 PM | #11 |
Rep 337
12-10-2015, 12:35 PM | #14 |
Rep 61
Called them again today and explained the situation again and they're standing by their claim. So i'm taking the car somewhere else to have the issue diagnosed and fixed. In the end to me it's not worth a huge battle with them over a couple hundred dollars.
2018 AW M3CS
12-10-2015, 04:32 PM | #16 | |
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
I bet they were just careless with the sensors either by removing them or just in a rush to get the dp's in letting the sensors dangle and knocking them around...just covering their ass trying to take advantage of you. I'd laugh in their face if they told me it was due to increased flow....Duh catless flow more than catted, it's an oxygen sensor not a flowmeter. Get it diagnosed properly and present them with the bill, mention you're a member of bimmerpost, writing a reveiw of this shop and tell us who so others can avoid their stupidity
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
12-11-2015, 12:47 AM | #17 | |
Rep 61
2018 AW M3CS
12-11-2015, 09:04 AM | #18 |
3441
Rep 79,211
Shop is just trying to put the problem on someone else. It's always the install and to be honest it might not even be their fault still.
O2 sensors are fragile and after an install or 2 they usually fail. It's hard for me to put 100% blame on them considering how easy it is for them to fail from uninstall/install. When I install o2 sensors, I treat them like a piece of glass. Consider backing off just a little bit on the shop and realize it's par the course on the install sometimes. |
12-11-2015, 09:41 AM | #20 |
Rep 2,189
Definitely get a new shop.
They don't even understand how O2 sensors work. The pre-cat O2 is exposed to the raw exhaust gas flow, the post cat O2 is exposed to the cleaned up exhaust flow. The difference in voltage pre and post cat is how the system knows the exhaust is being scrubbed by the cat. HTF do they not know this? Don't let thrm touch your car again.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
