11-28-2015, 08:25 AM | #1 |
Rep 8
f30 xenon coding
[/ATTACH]I have purchased bmw xenon headlights, and would like to code them in,
i connected my enet cable i can only go as far (pic1)..when i used dr gini i get the following error (pic 2),but i got a read see cafd file, is the cable faulty? how can i code xenons in,someone guide me please, thanks in advance Last edited by hypercar; 11-28-2015 at 09:29 AM.. Reason: pics |
11-28-2015, 08:42 AM | #2 |
Supreme Being
1804
Rep 5,425
You are missing the car specific data in the top window (where it's empty now in your pic 1).
Check the folder structure under the 'Main Series' folder, you need to have a 'Dist' folder in each one, if it's not there create it. This is in the latest instructions I think - do you have the instructions PDF? Essentially as it stands the software doesn't know what it's trying to connect to. Once populated you'll see a list of types, you select F30 (NOT Direct) and then connect. Let us know.... EDIT: Now edit your post and remove the first picture - you've just shared your entire VIN with the world (although I don't know what people are bothered by that!)
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
11-28-2015, 08:59 AM | #3 |
Rep 32,881
11-28-2015, 09:33 AM | #4 |
Rep 8
thanks for help and advice!!!
c:data/psdzdata/mainseries/YES FOLDERS THERE BUT NOT FOR F30? I HAVE F001 F010 F020 F025 F056 and some others but not F so shall i create a folder F030 any other folder i need to created for future use? F002 F003 F011 etc??? dist folder? can you forward me instructions pdf please , if i create F030 folder what do i put in it? same for F002 f003 etc etc? Thanks in advance Last edited by hypercar; 11-28-2015 at 09:52 AM.. Reason: update |
11-28-2015, 10:05 AM | #5 |
Supreme Being
1804
Rep 5,425
Look at page 3 for the 'DIST' folder.
F30 is covered under the F20 folder so no need to create another. If this doesn't work, your PSDzData files are too old for your car and you'll need to get the latest. Good luck.
11-28-2015, 11:10 AM | #6 | |
Rep 8
F020_15_07_503 F020_15_07_504 ? |
11-28-2015, 11:16 AM | #7 | |
Supreme Being
1804
Rep 5,425
I would suggest deleting your PSDZData folder and re-extracting the original versions to that location (again check instructions for absolute method). Then, once you only have one version its eh folder, you should see this structure: F020_15_07_504\odx\dist The 'dist' folder should be empty but it must be there. If it's not there create it in the above location. To be honest I think your issue is duplicate data files so the delete and re-extracting should help fix it.
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring Last edited by MarkG_M5Comp; 11-29-2015 at 11:50 AM.. |
11-29-2015, 07:12 AM | #8 |
Rep 8
Thanks, you have been most helpful
can you send me link for psdzdata link latest 2015 pls thanks Last edited by hypercar; 12-01-2015 at 04:53 AM.. Reason: update |
