11-26-2015, 03:56 PM | #5 |
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Trackstar have a few solutions- pricey though!
http://www.teletrac.co.uk/teletrac.c...flet%20fpo.pdf You can set it up so that if it is moved then you get notified immediately. If the keys get nicked then if you have the Cat5 or Cat6Advance it will alert immediately as well if anyone uses the keys without the additional ID devices.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
11-26-2015, 03:57 PM | #6 |
Rep 32,881
11-26-2015, 03:57 PM | #7 |
Rep 19,982
In some areas it's very hard to get insurance without one. And same again if you have a car worth £70k+.
And even if not, it's still going to help/deter in most situations.
11-26-2015, 04:21 PM | #9 |
Rep 369
I use a TomTom tracker, it's great, comes with a very easy to use app that you can access to show you where the car is along with the driving style of the journey (very good for when someone else is driving the car) we have them on all our cars. £265
I have the app, the Mrs doesn't |
11-26-2015, 04:41 PM | #10 |
Rep 11,292
Doesn't the car come with a build in "tracker" - the BMW Remote app? (Certainly on later cars).
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
11-26-2015, 04:47 PM | #11 | |
Rep 20,651
For £70k+ cars, they should come with alarmed anti jamming systems as standard. The best system would be LORAN, or rather MILOR (miniaturised version). Higher power, much harder to jam, works in underground carpark etc. |
11-26-2015, 04:51 PM | #12 | |
Supreme Being
1804
Rep 5,425
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
11-26-2015, 06:24 PM | #13 |
Rep 491
I know some you lot would laugh and don't see the point in one but I've had a save before when my car (not current BMW) was moved so I got a call from the tracker guys to let me know. It was actually being towed away for being parked on a single yellow at 9pm at night (scratches head) rather than stolen so it wasn't that bad.
I got a SmarTrack Trident installed for relatively cheap and they also do a one off payment that covers subscriptions for the duration of ownership - that works out cheaper if you plan on keeping the car for a while. Check here: http://www.mobile-tracking-solutions.co.uk/ or here: http://www.trackerfit.co.uk/smartrack-trident.html for good prices (first site will pricematch +5% off from the second so you can get it installed for less than both using that trick). I was doing quite a bit of research on what to get before I did and I don't think there is much to differentiate between various brands other than it being a Cat6 or Cat5 tracker (check to see which the insurer needs as a minimum), so I went for the best long term solution at a reasonable price point. If a thief is hell bent on taking your car then no tracker will come in his way - as others have mentioned you can get jammers that will block the signal. However, from what I hear, thieves usually take the car and dump it for a few days to make sure the car hasn't got a tracker installed. This is where the tracker would be most effective. |
